SOURCE: Fabric Softner section won't fully drain....
take your soap draw out pull the fabric softener tub out wash leave all of your soap draw in a bucket of hot water scrub with a brush this should clean a small hole which lets your conditioner out simply fix common fault m8
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
SOURCE: Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
