I am getting an error e7300 it give host name and as well ip address but still unable to scan email
Try this site current software
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
