Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica Minolta Bizhub 350
Dear Sir,
I have problem with this Konica minolta bizhub 350, is like the user used to scan document on this machine (which ofcourse have an IP address) and the scan copy used to appear on the user computer, as its was configured for that user computer IP. The user just have to select the scanner botton, next select the IP address were this document need to be stored (eg: Computer IP address) and the scan copy used to directly stored on the selected user Computer IP. But, now it doesn't its just prints one paper with Heading on it "MEMORY CLEAR REPORT". I tried switch off 30 sec - 1 minute switch on back is same.
Please Help me with a solution.
L. Gomes.
Posted by itmanager on
  • tiffyfalk May 11, 2010
    Dear Mr Gomes,you can tell me if you still have the same problem after following the mentionated steps? Thanks,T.White
Anonymous
    Problem Solver:
  • 15 Answers
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Posted on Jun 09, 2009
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
C0862 error code on Konica Minolta Bizhub 250
Sir could not find that code in the machine service manual.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 07, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error code konica minolta bizhub 350
Sir which is it the Bizhub 350 or the Di2010 to different ways to clear the C0500 code.
May 21, 2013 | Minolta Office Equipment & Supplies
How to get rid of vertical lines in scanned documents in bizhub 200?
Open the top cover of the machine and clean the small glass on the left hand side. Good luck.
Dec 27, 2012 | Konica Minolta bizhub 200 Printer
What driver do i use to scan using windows 7 for konica minolta bizhub 350 just upgraded computer and it won't scan now prints ok
I believe you must install the software from the bizhub disc and if that does work you can set it up to setup it to your email as a pdf
May 13, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
How do you scan to PDF on a Konica Minolta Bizhub 353?
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:
http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
Jul 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Multiple copy error
Turn OFF sorting and/or grouping in the finishing tab.
Sep 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Aug 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub C450
You need to place service call for the transfer belt.
As for Sally's question, select the "seperate Scan" button to combine multiple documents as one file. This will work with or without the auto document feeder.
Jun 11, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Open Questions:
See all Konica Minolta bizhub 350 All-In-One Laser Printer Questions
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,010 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
