Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
v
veronica m oliver Posted on May 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error message of F4 - Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Dayton Computer
Level 3:
  • Brother Master 1,640 Answers
  • Posted on May 10, 2014
Dayton Computer
Brother Master
Level 3:
Answers
1640
Questions
0
Helped
819208
Points
6396
You should have a manual for that device. Message errors are listed, and if you can't locate that information; go on line to Brother at the Web site and seek assistance from the company support.
1helpful
F4 code flashing and beeping when I power on the Brother CS-8060 sewing machine.
Hi there Ok .
: What does F4 error message mean? A: Foot controller disconnected Q: How to fix F4 error message? A: Plug in the foot controller jack if it's disconnected. If the foot controller jack appears damaged, replace it. Replace the foot controller if it's defective. Replace the main PCB assembly if the foot controller is connected and working properly.
Take care and don't miss a stitch now From Clive
W6441 Error message
google this with the model # and the brand along with the F4 error code
2helpful
What is the Brother Pacesetter NX-200 F4 machine error, and how do I fix it?
You will receive F4 error message, when there is a problem within the unit, internal circuit board.
Your Brother Sewing machine need to be service.
Good Luck.
1helpful
Error message F4
Hi.
F4 on Fisher and Paykel means that there is a problem with water temperature.
F4 in Whirlpool and other dishwashers means that there is a drain problem.
Regards.
G.
Nov 03, 2010 • Dishwashers
2helpful
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 • Ovens
F2 F3 and now F4 error message
F2 is oven temp too high
F3 is open sensor OR thermal fuse
F4 is shorted sensor
1.Check the thermal fuse
2. Check that the sensor is installed properly.
3. install new sensor.
Press F4
svjyrat
"always message to press F4 at the time of star up". this problem happen when CMOS detect any error. is also happen if CMOS battery fail (Chack sum error).
to solve this problem at first check CMOS battery (it voltage less then 3V or not) if it bad then replace it. u can buy this battery form any computer accessories shope.
or if u not connect floppy drive, and controller enable. if u desable floppy drive contoller from CMOS setup (in intel mother board is show BIOS setup) then this problem solved.
3answers
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Norman Weimar
Norman Weimar
k24674
