Question about Asko W6441 Front Load Washer
W6441 Error message
How do I fix error message F4 for the Asko W6441?
Posted by anna killigrew on
Bob L
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 413 Answers
Google this with the model # and the brand along with the F4 error code
Posted on Jul 29, 2015
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
F3 Error Message
F3 is a pump problem check the pump trap and clean it this should clear it up...
Aug 25, 2007 | Asko W6441 Front Load Washer
I have an f3 and f4 error code on asko washing machine front loader. i know what the error codes are just dont know where they are anyone can help I need it thanks
F3 indicates a problem with the drain pump. At the bottom left of the machine, theres a square cut-out. This is where the drain pump is located. Using a flat head screwdriver or similar object, insert in opening on right side and gently pry open the drain pump cover.
Once the cover has been opened, be careful when opening the drain pump, as there is always a little water left in the drain pump. Before you open the drain pump, place a small container on the floor below the drain to catch the water. Pull the small black hose from the door and let the water drain into the container. You can now open the drain pump to clean it out. Also clean the pump rotor at the back of the pump housing. Replace the drain cover and reconnect the drain hose securely back to its position on the door. Close the cover.
F4 indicates a problem with the water inlet valve. Make sure the water supply is fully turned on. If no water enters the machine, then turn water supply off. Disconnect the hoses from the water inlet valve to see if the strainer in the inlet connection is blocked. Reconnect the hoses and turn on water supply. Hopefully this solves your problem.
Feb 14, 2011 | Asko W6441 Front Load Washer
F4 error message. Cleaned out screen at water inlet and still get error message.
There may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out, Reconnect and try again. Hope this helps it works for me and saves ££££'s in repair fees
Oct 04, 2009 | Asko W6461W 24" Front Load Washer w/ Delay...
My Asko W6441 front load washer F3 message
Hello. You said that you checked the drain line for obstructions, but did you check the pump? I would remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check the pump for any obstructions (like the occasional stray sock) and check the pump impellers. Look for broken/missing blades and ensure that the impeller spins freely. If there are missing/broken blades or if you cannot get the impeller to spin freely, the pump is defective. You may have already done this, and if so I apologize. Anyway, hope this helped and best wishes.
Aug 28, 2009 | Asko W6441 Front Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Asko washing machine has no power
check your ground fault interupters (outlets with butons) under the sink and around the kichen
then check the breakers in your breaker box
finaly call a sertified tecnition
Jan 22, 2009 | Asko W6441 Front Load Washer
f4 code is sapose to be the thermister, i'm looking for whosale parts supplyer can you help?
Mar 13, 2008 | Washing Machines
F3 Error Message
The F3 error code relates to a pump problem Check pump trap and clean. Good luck!
Asko W6441 Front Load Washer Logo
326 people viewed this question
Top Asko Washing Machines Experts
Michael Thomas
Michael Thomas
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
