HP LaserJet 1022 Printer Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP 1022 Printer, OS X 4, printer jam
Reloaded Tiger (OS X 4) operating system on Mac Mini, downloaded incorrect driver, printed many pages of garbage, interrupted by turning off printer. When turned back on, a piece of paper was stuck, and upper red light flashes. I Don't know how to clear it.
Anonymous
Level 2:
Sniper:
  • Expert 79 Answers
  • Posted on Jun 18, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
79
Questions
0
Helped
31966
Points
229
Unplug it for a minute or so. Make sure all the paper is out. Turn it back on. Macs usually have their own drivers. Did it come with a disk. Please rate me
How do I connect to an HP LaserJet 1020?
As the Laserjet 1020 not officially supported by the OS, you will need to download and install the HP Printer Drivers 2.11 package which include the Laserjet 1022 drivers, those should allow you printing using your device.
Install the package by following the Download below:
http://support.apple.com/kb/DL907
After completing the installation go to System Preferences ' Print & Scan and click the Plus sign,
Select the listed printer and click the Print Using drop-down.
Click Select Printer Software and then select the Laserjet 1022 which should be available now.
Complete adding the printer and try printing now.
GuruAid.com
How do l download hp laser jet 1018 to mac book air.
The 1018 is not supported by HP with the Mac OS Mountain Lion. I found this on an HP forum and it worked for someone else. You could try this:
Thank you for posting,
Unfortunately, HP laserjet 1018 is not suported in Mac OS X 10.8 Mountain Lion. How evere you can use the builtin drivers that goes along with the operating system and select teh driver of another printer and check.
Connect the printer to the computer and then go to System Preferences and click on Print and Fax. In the Print Fax window, lick on the Plus sign and you will find the printer, please select the printer and then under print using click on the drop down and click on "Select print Software" and in the list, please select HP Laserjet 1015 pr HP Laserjet 1022 and check.
If you don't find these printers in the list, please download and install the latest print driver version 2.12 from the apple web site using the link below.
After downloading and install the update, please try the steps given above.
HP Photosmart C6280 Scanner not found with Mac Tiger
I'm using a software called VueScan, which has drivers for almost all scanners and works well. Maybe you should test it?
1helpful
HP laser Jet 1022 only prints one page at a time
Jan 2013 Installed this new printer driver and all my HP 1022 problems disappeared; now printing perfectly back as usual!
HP Printer Drivers v.2.13 for OS X
Click on the link above or copy and paste the following address into your Web browser to view the article:<http://support.apple.com/kb/DL907?viewlocale=en_US>
1helpful
2answers
HP Photosmart C3180 All-in-One printer, Scanner, Copier will not scan with Mac OS 10.4. The button flashes for a few seconds, then stops and nothing happens. No image appears on my computer screen.
All lot of those printers came with two separate driver's disc. Make sure that you are installing the correct for the mac and not windows. If you are you can go to the hp website and do a search on there website for the driver for mac operating system.
If printer runs out of paper and you refill starts
The continuous printing issue can be fixed following this link
http://www.fixya.com/support/r5095488-unable_print_hp_printer
Regarding Gibberish printing or say garbage printing, If the above utility does not fix this issue, probably the printer drivers are corrupted, and you may have to uninstall the printer software from your pc and download and reinstall the latest drivers. this link below will let you choose the operating system of your PC and download the drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=60426&lc=en&cc=us&dlc=en&lang=en&cc=us
2answers
No up to date print drivers for hp laser jet 3330 for mac os 10.5
Its a huge posibility that the drivers you are currently using is not compatible with the device. There are many reasons for the same:
  • The drivers installed is not compatible with the windows installed on the computer.
  • Incorrect drivers installed.
To avoid this problem, visit the following link and download the drivers for your printer and I am sure you will face no problem.
Note: Make sure you download the drivers based on the operating system installed on your computer (like Windows XP, Vista, etc)
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=66367&prodSeriesId=66359&prodTypeId=18972&taskId=135&swLang=8
Printing problem
hi,
You need to reinstall the printer driver.
First check which operating system is used with your product? After that download the software from Download  Full Feature Software and Drivers.
How to Uninstall the printer Software :-
Follow the steps below to remove the hp LaserJet 1020 series software from the computer:
  1. Disconnect the USB cable from the computer.
  2. For the Windows Desktop, click Start , click Programs or All Programs , and then clickhp LaserJet xxxx series .
  3. Click Uninstall hp LaserJet xxxx series .
  4. Follow the messages on the screen to remove the software.
  5. Reboot the computer when instructed.
OR
2. For the Windows Desktop, click Start , click Crontrol panel, select add\remove(XP) or program future (VISTA).
 After restart install the printer driver and follow the screen instructed.
Scanner won't operate on HP PSC1410 All in one with Leopard
Hi, as per HP's support page on this product here
It seems that there aren't any drivers compatible with Leopard for this printer at the moment. The latest OS supported is Mac OS X Tiger... You will have to wait untill HP do something for leopard...
k24674
Grand Canyon Tech
Grand Canyon Tech
