Check if your memory's Mhz is compatible with your MOBO or if you have installed the right capacity for each slot. it will eventually affect the hard drive and board, if it is not fix.
Did you checkup your PC health Online or just installed PC checkup utilities newly downloaded? If yes and that was the beginning of such errors you maybe infected by viruses or Malwares. Uninstall newly installed programs and run Anti-malware or antivirus.
This sounds like either a hard drive problem, when you power on the laptop there should be an option to enter BIOS or Setup (usually F2) once inside of the BIOS you should be able to run a diagnostic. and that will tell you if there is anything wrong with the hardware. If everything passes that test. you may have some serious Virus problems.
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
It seems to me that the memory for your graphics card is not enough to play the game .64MB is quite small for that sort of game. If you check the mininum requirements for your game .
