Disable Unnecessary Services There are too many hidden services
running in the background at system startup which may be a cause of
laptop freezing. You can disable unnecessary services from the start up
by following the guide below: Run Disk Checkup Disk Checkup is a very good method to
fix laptop freeze. Disk checkup helps you to remove the errors that are
causing laptop freezing problem. You can follow the steps below to run
disk checkup: Disable Startup Programs Disabling Startup programs can help you
to fix laptop freezes randomly problem. Follow the steps below to
disable unwanted startup programs. Clean Registry Errors Corrupt registry causes many problems
due to which laptop freezes randomly. Registry gets corrupted when it
is overloaded and it starts generating errors. To fix registry errors
quickly, use a powerful registry cleaner and PC optimization software. Tired of Laptop freezing? Want to fix
this problem for good? The easiest way to do so is to install the Intel
Software Partner RegInOut. To download RegInOut click here.
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
