Maxtor OneTouch II 300 GB Hard Drive Logo
Posted on Oct 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No recognize All of a sudden computer was dead making noise in the maxtorAnd i tried to reboot my computer it couldn't start and same thing happened which the maxtor hard drive kept making noise.So i removed the drive and disconnected the hard drive from computerthen reinstall the drive with the installation cd and connected the hard driveto the computer.But the computer never recognized the hard drive and never finish the installation.after installation computer restarted and finish the rest of the installation but it's just stock thereand ever since i reinstalled the hard drive the blue light keep blinkingplease help mei got a lot of things in the hard drive ASAP
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 382 Answers
  • Posted on Oct 29, 2007
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
382
Questions
0
Helped
159768
Points
449
The drive will need to be extracted. The enclosure and/or drive has failed and is causing your computer to fail. Remove the drive carefully from the enclosure and test it in a good, known working stable enclosure...
www.drivesavers.com
keep me posted
My computer will not recognize apple products
Do a system recovery to a date the system worked ok. The system recovery is in programs then click Accessories then under the tool menu.
Hi i have a Dell Poweredge 2650 and i wanted to make some software chages (reinstall windows etc) I had to reboot it a few times (2/3x) and suddenly i started halting on boot with the message. Plug &...
There could be many things that could cause your halt problem. From my experiencew ith servers the first thing I would do is try resetting your BIOS setting to default. Also, reset the jumpers to clear out the CMOS and retry your install.
Keep us posted. Good Luck
C2Solutions
My computer had some problems so i rebooted it but when the windows xp logo came in it suddenly stops and starts making weird noises. It also happened before i rebooted when i watch some videos online.
Sounds like your hard drive is crashing or has crashed. You will most likely need to get a new hard drive and reinstall Windows on it. I hope you have your important files backed-up.
Computer doesn't recognize hard drive
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
I've had this a year. When I hooked up to the
Use a card reader instead of your camera and download to a folder you create on your desktop.
Maxator hard drive not being recognized
Well all good things must end and it sounds like this one has. If it doesn't connect in either computer then something inside has either been bumped loose or it's broken.
Macbook Wont Recognize
Try the drive in another computer.
If it doesn't work it is dead...
Ipod 4gb nano problems
http://serviceman.site88.net/index_files/Apple_Ipod.htm
5answers
Can't get connected
There are 3 possible things wrong. You will have to try to test them all. 1) The USB port could be bad. Try plugging another USB device into it and see if the computer recognizes it. Try a USB mouse, portable music player, or any other type of USB device. If it does, then the port is good, and move onto #2. If not, then try another port. If all USB ports are bad, then you will need to have that fixed. 2) The USB cable may be bad. Try swapping out the USB cable. Try using a different USB cable. Also try using the original USB cable with another USB device on another computer. 3) The printer may be bad. Contact vendor support, or just return is to where you purchased it. Another place to see if the device is even being recognized is the Deviec Manager in windows. This can be viewed by Right clicking on My Computer and selecting "Manage". In the Computer Management window that opens, select Device Manager. If you see any question marks there, then your computer may "see" the printer, but the drivers are not installed properly. If you do not see any question marks or the printer, then there is a problem with the printer.
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
