SOURCE: NEED a User Guide for saeco vienna superautomatic
http://www.saecooutlet.com/index.asp?PageAction=VIEWCATS&Category=26
SOURCE: Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end
of the grinding cycle. Make sure that the grinding chamber is
completely cleaned and dried before using the grinder.
SOURCE: My Saeco Easy superautomatic machine will not
maybe your valve dont open water or your brew unit plugged out.unscrewed two screw on top brew unit and you will see sprin and small plastic ball ,clean inside and try
SOURCE: cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
