Hi there
the HL 2040 only prints one line of text from the page, and a few lines from underlined sentences, the rest is left off
tried to find drivers to re-install, but cant seem to find anything other thatn Driverdetective, which I'd prefer not to use?
which program ? Underline Text in HTML b> Find or enter the text you want to underline. Place the text within a SPAN element, by adding an opening tag before the text and closing tag after. Specify underlining of the text within the SPAN by adding a STYLE attribute to it as follows: STYLE="text-decoration; underline; " Add a CLASS attribute to the SPAN, giving the name of a CSS class which defines text underlining. This is an alternative to using the STYLE attribute as described in the preceding step. The format of the CSS class declaration is as follows: .my-underlined-class { text-decoration: underline; } b> Underline Text Using HTML b> Find or enter the text you want to underline. Enclose the text within a U element, by placing an opening and closing tag before and after the text. Underline Text in PowerPoint PowerPoint includes shortcuts for adding font effects, such as strike-through, italics or subscript, to any text in your presentation. Like other products in the Microsoft Office Suite, PowerPoint also allows you to underline important words or phrases on a slide to help empha important aspects of your presentation. Microsoft's use of hot-keys makes it possible to underline text identically in all versions of PowerPoint.
View the slide that has the text you want to underline. Highlight the text you want to underline. Press "Ctrl" and "U" simultaneously to underline the highlighted text. Underline Text In Word 2007 b> Microsoft Word 2007 makes it possible to create and edit documents for email or printed use. This word processing application allows you to add a number of formatting options that enhance your document. One of many features included in Word 2007 is the ability to underline words or sentences. You can make certain words stand out using either basic or decorative lines.
Open your Microsoft Word document and highlight the word or sentence you want to underline. Click the "Underline" icon located on the Home tab to underline the text. Select the text you want to underline, if you want to underline words, but not the spaces between them. Click the "Font" button on the "Home" tab and click the "Font" tab. Click "Words only" in the "Underline style" box. Select the text or sentence you want to underline, if you want to double underline. Click the "Home" tab and click "Font." Click the "Font" tab. Select "Double Underline" in the "Underline style" box. Select the text you want to underline, if you want to add a decorative underline. Click the "Home" tab and click "Font." Click the "Font" tab. Select the decorative underline you want to use in the " Underline style" box. Click "Underline color" and select the color you want to use for your decorative line. Click "Paragraph group" on the "Home" tab if you want to underline spaces. Click "Show/Hide" and press the "TAB" key. Select the tab characters that you want to underline. The tab character looks like an arrow. Press "CTRL," and "U" together for a basic line. Click "Font" on the "Home" tab if you want to add a decorative line to the space. Click "Underline style" and select the style you want to use. Hope this helps.
Remove the printer cartridge and check for any obstructions. Then replace the printer cartridge and attempt to print again. Make sure the cartridge is fitting firmly. Check the printer menu for a cartridge cleaning option. Print a test page by right clicking the printer, selecting Printer Properties and Print Test Page.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
wow..I could be the FIRST..I am impressed..NOT! check to see if there is ink, by blotting the print head on damp paper towel. otherwise..delete and reinstall the printer. could be a software problem.
hi!
have you check you toner, it has a white strap, you need to strip it to open the nozzle of your toner. but before you do that you need to shake it first to have a sharp print out before you would strip that white strap. have a nice day
Make sure the paper aligning slides are tight to the sides of the
paper. In the case that they are spring loaded make sure there is not
something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears
crooked it is related to the print head assembly. If the text is not
aligning to the edge of the page then the paper is not feeding straight
and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping
the paper and it is forcing it to one side as it pulls it in.
