When starting up the laptop it states that it is "Resuming Windows" but nothing is happening.
SOURCE: I have a Dell XPS
hi,
Please keep tapping F8 key when Dell logo comes and advanced options will be coming.
>choose safe mode
>see the system is starting in safe mode
>if starting then Go to programes>accessories>system tools>system restore and restore it by pressing next tabs till finish and the system will restart and issue will be resolved.
>if the issue is not resoved kindly revert with the results.
SOURCE: resuming windows
Guess the error code is that of the diagnostics in built in the dell systems.
This error code indicates a problem with the Hard drive. It can be resolved by reseating the hard drive and the optical drive. Kindly look in to the manual and look for the location of the hard drive. It will have 2 screws which needs to be removed after which the hard drive can be pulled out. Optical drive will have one screw embedded deep inside.
Place the hard drive and the optical drive back in its place and then test for the error code.
Please turn off system and remove the battery and the AC adapter when performing these steps.
SOURCE: Will not boot up. Has Power. I have pushed F8 -
Click here to know how to reset the computer back to factory without the cd's. once you open the article click on pc restore. STEP 2.
Testimonial: "Step two was the solution. Appreciate the support."
SOURCE: vostro 1500 does not boot
hi
dear it is not note book problem it is windows problem
insert boot cd of your desire windows repair it
thanks
SOURCE: blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
