Try holding down the power key to force it to power off. Power it back up again and you should get the Windows Resume Loader with the following options "Continue with resume" and "Delete resume data and continue with startup". I can't remember the exact wording of the options, it may be different but you need to select the later or second option "Delete resume data and continue with startup".
run in safemode
Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs
Please remember to clean Windows registry using registry cleaner reg in out
The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
I'll asume something for this one it might help. Make sure your laptop is completely turned off [No fans turn, screen black, no hard drive light]. When you then press the power button, immediately keep pressing the F8 button on your keyboard. It should then actually display two options after a while :
*Delete restore/resume point and start windows *Resume restore/resume point
Select 'Delete restore point' and the unit should boot up fine again.
I had a unit that was basically turbo-booting into windows, but the restore point was corrupt and it always seemed it had a 'blank screen' problem.
You can also try to access the BIOS by pressing F2 as soon as the unit starts up to see if you can actually access the BIOS.
How do you switch off you laptop? Try this press and hold on the power button for about 5 seconds. So it won't boot to windows? When you turn on the laptop and you see the dell logo keep tapping on F8 then try booting in safe mode, if fails do F8 again then last known good configuration, if fails do F8 then startup repair, if fails do F8 then system restore, if all fails reinstall os. but before all these steps try to test hdd first. make sure laptop is off. press and hold on the Fn key then press power button. Run the PSA test and once it finish it will show you some errors code like 0142 -0146 means hdd needs to be replaced.
press f8 at startup to get to the windows startup menu, choose "last known good configuration" If that fails, you can choose "disable automatic restart" and the BSOD, Blue screen will appear and give you an error, you can also goto safe mode with the f8 key on startup, choose safe mode, and then click yes at the prompt to start the system restore, pick a date and time the PC worked, and try that.If that doesn't work, you need to restore the PC to factory default state, by using or purchasing restore disks, you would have been asked to make them when you 1st powered on the PC, if you don't have the CD's call HP and order them.
This is hopefully a possible fix. I have encountered a similar problem with windows xp and vista. the fix I found that will eliviate this problem and a startup-reboot-startup-reboot... If you have your original windows (xp or vista) CD lounch it like you would do to do a system install. As the installation starts it will show ask you if you would like to do a recovery using the recovery console, just press ESC and go on. Press the F8 to accept the license. If Windows is not completly broke, it will find the original installation on your hard drie. It will ask if you want to repair. Press the R key and windows will reinstall your operating system, without destroying your software or data. After it is done the system will go to the windows startup screen. You will need your windows product key located on your machine or on the original software packaging.
I hope this will fix your problem.
when the computer is booting up hold F8 to go to the windows advanced options menu
it will give you options to boot from last known config as well as safe mode
