Bosch Nexxt 800 WFMC8401UC Logo
A
Anonymous Posted on Jan 23, 2014
Diagnostic mode - Bosch Nexxt 800 WFMC8401UC
How to enter diagnostic mode on Electrolux ewmgd70jppo
Please follow these procedures to activate the diagnostic mode on an Electrolux EWMGD70JPP0 dryer:
Ensure that the dryer is unplugged from the power source and turned off.
The "CANCEL" and "START" buttons should be pressed and held simultaneously.
Reconnect the dryer's power while continuing to hold down the "CANCEL" and "START" buttons.
Holding the "CANCEL" and "START" buttons together will start the diagnostic test.
That should only take a few seconds.
Once the diagnostic test has begun, let go of the "CANCEL" and "START" buttons.
Now that you should be in diagnostic mode, you can go through the various tests using the display.
The "CYCLE SELECT" knob and the "OPTIONS" button should be used to cycle through the tests, respectively.
The diagnostic mode should only be used by those who are qualified to work on appliances, as it is designed for service technicians.
It is advised that you get in touch with a reputable appliance repair provider if you are unfamiliar with the diagnostic mode or are unclear on how to proceed.
Where is the BCM located in 2004 Oldsmobile silhouette?
BCM Identification
This vehicle is equipped with 1 of 3 types of BCMs. The BCM type installed on this vehicle is based on the vehicle equipment, point of sale, and option content.
Refer to On-Board Diagnostic Features for more information on how to identify the BCM type installed by using the on-board diagnostic feature. The following identifies the functions and basic option content of all 3 BCM types:
BCM Type 2
BCM type 2 is the base BCM that provides all standard BCM functions. Refer to the BCM function table for type 2 BCM.
BCM Type 3
BCM type 3 provides all of the features of the BCM type 2 plus keyless entry. Vehicles with RPO AU0 are equipped with a BCM type 3.
BCM Type 4
BCM type 4 provides all of the features of the BCM type 2 and type 3 plus content theft deterrent. Vehicles with RPO AU0 and UA6 are equipped with a BCM type 4.
This vehicle is equipped with an on-board diagnostic feature capable of performing the following functions:
• Feature Customizing
• Displaying DTC codes
• Clearing DTC codes
• Input/Output Diagnostics
Feature Customizing Mode
The feature customizing mode is used to configure the BCM to function in various applications. The BCM can be customized to change the following vehicle functions:
• Interior Lighting Features
• Door Lock System
• Keyless Entry System
• Content Theft Deterrent System
In order to enter the feature customizing mode perform the following steps:
Turn the ignition switch to the LOCK position.
Remove the BCM PRGRM fuse.
Turn the ignition switch to the ACC position.
When entering the feature customizing mode, the BCM first identifies what type of BCM is installed on the vehicle by flashing the fasten seat belts indicator and sounds the chime 2, 3 or 4 times depending on the type of BCM used on the vehicle. There are 3 different types of BCM that can be installed on the vehicle based on the vehicle option content that matches the BCM capabilities. Ensure that the BCM installed on the vehicle is compatible with all of the features on the vehicle. Refer to Body Control System Description and Operation for BCM identification.
For more information on features that can be customized, refer to Personalization Description and Operation in Personalization.
Displaying DTC Codes
The DTC codes can be displayed by entering the diagnostics mode. Clearing DTC codes and Input/Output Diagnostics are also available in the diagnostics mode.
Complete the following steps in order to enter the diagnostics mode:
Quickly turn the ignition switch from the ACC position to the LOCK position then back to the ACC position within 1 second.
The BCM will enter the on-board diagnostic mode and flash the fasten seat belts indicator and sound the chime equal to the number of DTCs stored in the BCM memory. If no DTCs are stored, the BCM will not flash the fasten seat belts indicator or activate the chime.
The BCM flashes and sounds the first DTC with the lowest number, pauses, then continues with the next DTC until all of the DTCs are read. With a DTC 1, the BCM will only sound the chime once, and the fasten seat belts indicator may not flash. Once all of the DTCs are read, the BCM repeats this sequence 3 times.
Important: If the fasten seat belts indicator does not flash, and the chime does not sound, complete the following procedure in order to confirm that the BCM has entered the diagnostics mode:
Ensure that all of the vehicle doors are closed.
Open and close any vehicle door.
Fasten and release the driver seat belt.
The BCM sounds the chime when receiving an input signal such as Drivers door, Passengers door opening or turning on the courtesy lights when the BCM is in the diagnostics mode. Make sure these inputs are working correctly in order to prevent a false diagnoses.
If the BCM does not sound the chime upon opening a door or turning on the courtesy lights, repeat Step 1 of Entering the diagnostics mode. If the BCM does not enter the diagnostics mode, then refer to Cannot Enter BCM Diagnostics .
Clearing DTC Codes
After entering the diagnostics mode press and hold the Unlock switch for 4 seconds. The BCM will erase all history DTC codes. If a circuit is still shorted, the BCM will immediately store a history DTC code.
Input/Output Diagnostic Mode
After the BCM reads all of the DTCs in the memory, the BCM enters the Input/Output Diagnostic Mode.
The BCM flashes the fasten seat belts indicator and sounds the chime once when any of the following inputs are activated:
• Courtesy lamp switches
• Door lock cylinder switches
• Driver door ajar switch
• Headlamp switch
• IP compartment lamp switch
• Keyless entry request for door lock/unlock
• Keyless entry request for the alarm (RPO UA6)
• Passenger door ajar switch
• Power door lock switches
• Liftgate ajar switch
• Sliding door ajar switches
• Shock sensor
• Hazard switch
Perform the following procedure in order to test the BCM outputs:
Ensure that the BCM is in the diagnostic mode. Refer to Entering On-Board Diagnostic Mode.
Cycle the interior light switch ON then OFF.
The BCM will enter the Output Diagnostic Test Mode 1.
Each cycle of the interior light switch ON/OFF will select from following test modes depending on BCM type:
• Test Mode 1-- De-activates the courtesy lights output and removes power to all of the interior lamps.
• Test Mode 2-- Activates the courtesy lights output and provides power to all of the interior lamps. Interior lamp override switch must be ON.
• Test Mode 3-- Activates the courtesy lights output and turns ON all of the courtesy lamps. Interior lamp switch must be ON.
• Test Mode 4-- Activates the theft deterrent relay for 1 second and turns ON the headlamps. BCM type 4 only.
• Test Mode 5-- Energizes the horn relay for 25 ms. BCM type 4 only.
• Test Mode 6-- Turns on the security LED indicator. BCM type 4 only.
• Test Mode 7-- Turns off the security LED indicator. BCM type 4 only.
When the BCM completes all test modes, the BCM will repeat the test mode sequence.
Exiting Diagnostics
Perform the following procedure in order to exit the BCM diagnostics mode and return to normal BCM operation:
Reinstall the BCM PRGRM fuse.
Turn the ignition switch to the RUN position.
© 2018 General Motors Corporation. All rights reserved
2answers
2003 silhouette sitting in garage with key out and the doors keep auto locking???
A normal function of many modern "thinking" cars.
If you need it to remain unlocked you could leave a window open or leave a door on the first catch or leave the spare key in the ignition...
Enter diagnostic mode in mod 11028002010 toploader he washer
Washer topload diagnostic mode. - YouTube
? 5:00
https://www.youtube.com/watch?v=jipYd_qeCqs
Jun 17, 2014 - Uploaded by Al Fixit
How to put kenmore washer into diagnostic mode. ... How to Use HE Top Load Washing Machine: Informational Tips From Sears Home ...
Entering Diagnostic Mode in a Whirlpool Vertical Modular ...
? 1:02
https://www.youtube.com/watch?v=7kWrIPaWLUM
May 8, 2012 - Uploaded by SamuraiRepairman
Shows how to enter diagnostic mode in the Whirlpool VMwasher. Created on May ... The first was no error codes. the second said that we had an unbalanced load. I'm not sure ... I had a repair person out to my house he reset the computer panel and it worked. Now its ... washer. Raise the top panel to get it.
Diagnostic mode for Kenmore Elite Oasis HE Top Load ...
1helpful
2answers
What does code po745 mean on a 2004 lincoln ls v8
Here are some code definitions: I am also including a link to a forum discussion of the problem. The forums can be very helpful.
P0745 Pressure Control Solenoid Malfunction
P0745 OBD II Trouble Code
2000 LS transmission P0745
Kenmore High Capacity Dryer won't go into diagnostic mode
faulty touch panel key pads are the most likely suspect. Prior to diagnostic you should be able to enter the fault code memory to reference what fault codes are stored in the main board. Pleazer Appliance...
2helpful
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
9helpful
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2009 • Dryers
2helpful
2answers
MY TROUBLE LIGHT IS STAYING ON
2000-2004
The Diagnostic Mode is entered by turning the ignition from OFF to ON while holding the reset switch in. The normal power-up sequence will occur before entering the diagnostic mode. Diagnostic codes set during this power-up sequence will be stored as well.
Important Note: Be sure no diagnostic codes are indicated before reset is held in for more than 5 seconds or diagnostic information will be lost.
When in diagnostic mode the odometer will display the first diagnostic code. When the trip switch is pressed again the next code will be shown. If the trip switch is pressed for more than 5 seconds at any time while in the diagnostic mode, the diagnostic code displayed will be erased.
There are 7 different diagnostic codes available. They are as follows:
d01 - Speed sensor power output shorted low
d02 - Speed sensor power output shorted high or open
d03 - Not Used
d04 - Not Used
d05 - Speed sensor return shorted high
d06 - Speed sensor return shorted low
d07 - Not Used
d08 - Speedometer power over voltage
d09 - Speed output shorted high
d10 - Speed output shorted low or open
CAL XX - Speedometer application calibration number:
14 = Domestic
15 = HDI
When in the diagnostic mode, all codes are displayed in sequence from d01 to d10.
As a code appears in the display (for instance d02), it will read "d02Set" if set or "d02CLr" if clear.
The diagnostic mode is exited either by turning ignition from ON to OFF to ON again without depressing the reset switch or if a speed signal greater than 5 MPH is detected.
Diagnostics cannot be performed if system voltage is less than 9 VDC or greater than 16 VDC. The only exception is d08 which is set when system voltage is greater than 16 VDC.
After all the diagnostic codes are displayed, the speedometer calibration number is displayed (CAL 14 for example).
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
