The explanation you are about to read will reset your admin password though be warned, any documents saved to your HDD that are retrieved through the document filing feature will be lost.
YOU HAVE BEEN WARNED!!!!!!!!
Enter simulation as follows:
Double tap the HOME key on the copy count screen tap the version number in the bottom right corner eg ver 1.01. At the next screen tap # * C * Now enter 62 and press the MONO key, now press 08 and again press the MONO key.
This gets you to the command to format the HDD except for system area. I know this appears scary but fear not. Press the EXECUTE button in the bottom right of the screen and confirm YES.
This may take a while, I have known it take up to one hour but be patient it will reset the admin password for you causing no damage to the machine. The only thing that you will lose is any documents you have saved to the HDD.
Good luck
SOURCE: resetting password
go to setup>and go to maintanance -->there is a option restore default>select that and after some time do power cycle>and rste me solved if its helps
SOURCE: CS-1820 admin password reset.
The master user name is 1118 and password 1118 also. this should give you access to the menus and allow you to do whatever changes you feel like.
SOURCE: Cannot change network settings - Admin password unknown
Got in with random trialling passwords for the Administrator... finally found the default password for Administrator on the Sharp MX2300N was "admin". Should have known...
Got in, set up the IP's and away we go again. Did not have to go in with any maintenance mode or re-setting the whole system.
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
SOURCE: default admin password?
Is the installation software being installed on an account with administrator privileges? If not, log off and log back on with an account that has admin privileges. If your account has admin privileges, and the install asks for the password, and you know you have not set such a password, pressing the enter key may skip this problem.
