***Panasonic NN-S615BF is the REAL model of my Microwave Inverter Oven. It wasn't on the list below.
Recently, my microwave oven has begun BEEPING out of the blue (when it's not being used) and the display starts counting down: P 10, P 9, P 8, P 7, etc. When it reaches P 1, the countdown begins again. Only unplugging the oven stops this countdown.
This problem only occurs when the oven is plugged into a particular outlet in my kitchen.
Thanks for the quick reply -- but what does "neutral ground" mean? I should say that this entire outlet was replaced by a licensed electrician a few months ago.Thanks for the quick reply -- but what does "neutral ground" mean? I should say that this entire outlet was replaced by a licensed electrician a few months ago.
I just need clarification for what "neutral ground" means. I'm an electrical ignoramus.I just need clarification for what "neutral ground" means. I'm an electrical ignoramus.
Hello, my Panasonic 1250W Genius Sensor microwave just began doing the same P-countdown. None of the buttons work. This occurred within hours of using the microwave normally. It has been in the same plug for many months and has worked terrifically.Hello, my Panasonic 1250W Genius Sensor microwave just began doing the same P-countdown. None of the buttons work. This occurred within hours of using the microwave normally. It has been in the same plug for many months and has worked terrifically.
You can't post conmments that contain an email address.
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
It certainly sounds like something is wrong. My first GE microwave was like this and it wasn't advertised as anything special. After a long life I replaced it with a Sharp (makes most all microwaves) and was disappointed at the cycling on and off. Now Panasonic makes what they call Inverter microwaves with continuous power. I recently bought a GE (probably made by Panasonic) with this Inverter technology and am very pleased with it. Make sure the microwave you have says AccuWave on it, if it does, it sounds like the magnetron may have been replaced with a non-continuous type of magnetron. Was it bought refurbished/returned/clearanced? I think when I was researching this that it MAY have something to do with the type of power supply to the magnetron and not so much the magnetron itself.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts Microwave Type:
Over-the-Range
Cooking Power:
1200 Watts
Capacity:
2 cu. ft.
Convection Cook:
Without Convection Cook
Dimensions
Exterior Depth:
15 in.
Exterior Height:
9.5 in.
Exterior Width:
23.25 in.
Miscellaneous
Product ID:
22541798
More Information
Details:
Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
If
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
It may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
