The electricity went off last night during a storm and now the Microwave is on Demo. How do I turn...
(More)
The electricity went off last night during a storm and now the Microwave is on Demo. How do I turn it off?
Hi there Not sure if you can help. I just need to know the RRP of PanasonicDimonsion 4 Inverter...
(More)
Hi there Not sure if you can help. I just need to know the RRP of PanasonicDimonsion 4 Inverter Microwave oven NN A7725BBPQ please. Many thanks Carrie
turns off after 3 seconds cause was a friend used it as a timer with nothing in it running it very...
(More)
turns off after 3 seconds cause was a friend used it as a timer with nothing in it running it very hot. now even after leaving it off overnight the microwave stops after 3 seconds. Thanks Bill
This is a combination microwave/convection oven which has given excellent service. Recently, the...
(More)
This is a combination microwave/convection oven which has given excellent service. Recently, the control panel has gone blank, and nothing functions (no clock, no interior light, etc.). Have check power supply which ok. Any suggestions? Thanks, Pad.
The microwave could be in "Demo Mode" - Check your owners manual. In Whirlpool/Kenmore models this is indicated by a lower case...
written by ptishkevich
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor,
the rectifier diode.or the magnetron.
The...
written by ginko
A microwave not heating up is caused by one or more of the following -
1) Failed controller board (unlikely if you are getting a clock readout
and...
written by MrMark52
Problem: Totally dead oven.
Possible causes:
No power to outlet (blown fuse or tripped breaker or GFCI).
Blown main fuse - likely due...
written by sweet_rascal
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I...
written by UNCLEMOE
I was also told that I would have to pay a technician to come out to replace the interior light bulb in my Advantium speedcook microwave, but after...
written by kersti
If it is displaying error H97, or h98, this generally means that the invertor(power supply Panasonic part
number: Z606YM300BP,) is not functioning. ...
written by robotek
What can go wrong
The most common problems occur in the microwave generating portion of the
system, though the controller can be blown by a...
Splatters of food from microwaving look bad, smell bad, and decrease the efficiency of your microwave. Fortunately, microwaves aren't hard to clean if...
by wikihow
