20 Most Recent Panasonic Kx-tg4131m Dect 6.0 Plus Expandable Digital Cordless Phone System Questions & Answers
No one can tell you without looking at it. You need to ask yourself how old is, what did you pay for item what does a new similar model cost, You can look at other brands = Ask yourself what do you cook in it, do you need all the features s and the size, Personally i would replace it.
Panasonic... | Answered on Jun 18, 2019
Need more info like the model number which is printed on the back. It should also show the wattage on the same sticker.
If you can't find these and it was only a home microwave it was most likely only a 700 or 600 watt.
Panasonic... | Answered on Jun 14, 2019
Well....the first thing you need to check is see if you have power going to your RY9 relay. If you do, there is a good chance the relay is bad (if you haven't already) If you don't have power going to that relay, you have to trace where the power is being lost. Fuses is usually a go to. According to the schematic there is an inductor in line with the netural line, check that. As well as an inductor with the lead, and several fuses.
Panasonic... | Answered on Jun 13, 2019
I bought another Panasonic microwave oven yesterday. (problem solved)
Thanks
serge_corriv
Panasonic... | Answered on Jun 11, 2019
Ask your self how old is the unit how much did you pay what does a mew unit cost. The price has fallen sharply but may be 25% higher with tariff.You may money invested in an old unit.
Panasonic... | Answered on May 26, 2019
To erase a number from your blocked calls list;
Press  [MENU] [#] [2] [1] [7]
Press the [?] or the [?] button to select "Block a single number" or “Block range of numbers", press "SELECT"
Press [SELECT]Press the [?] or the [?] button to select the telephone number that you want to erase.
Press [ERASE]
Press the [?] or the [?] button to select [YES]
Press [SELECT]
Press [OFF]
To erase all blocked numbers;
Press  [MENU]
Press the [?] or the [?] button to select "Erase All", press "SELECT"
Press [SELECT]
Press [SELECT]
Press [OFF]
Panasonic... | Answered on May 21, 2019
H98 is no power to the magnetron. Usually caused by a failed magnetron or power supply failure.
Panasonic... | Answered on May 14, 2019
That depends...
It depends on how much the repair will cost and how long it will be before another repair is needed - these are unknown quantities but you could ask your local repair shop and a Panasonic dealer how much for a repair estimate.
Mostly if you go ahead with the repair the cost of the estimate will be waived. If you don't go ahead you should be able to negotiate the estimate cost as a discount off a replacement - if you use a Panasonic dealer.
10 years of hard work from a premium microwave should be as nothing when you consider my old Sharp Carousel lasted me 29 years of daily use, but then things today aren't built as well as they used to be.
I suggest you decide on the cost of a likely replacement model before you go ahead, follow the link below to begin your search. In the final analysis a repair is a bit like making a wager while buying new with a warranty is like putting your money on the favourite...
https://www.panasonic.com/ca/consumer/home-appliances/microwave-ovens.html
Panasonic... | Answered on May 13, 2019
In this manual it has a symbol for sensor cooking which will display when sensor is in use it looks like a dish with curved lines over it. Not sure if that is what you are talking about
manual belowhttps://www.winningappliances.com.au/public/manuals/Panasonic-NN-ST776SQPQ-44L-Inverter-Microwave-Oven-User-Manual.pdf
Panasonic... | Answered on May 05, 2019
Go to the Panasonic product support website for manuals.
Panasonic... | Answered on Apr 06, 2019
Panasonic Kx-tg4131m Dect 6.0 Plus Expandable Digital Cordless Phone System Logo
1 questions posted
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Microwave Ovens
Most Popular Question
panasonic genius inverter microwave
  • Microwave Ovens
