20 Most Recent Panasonic Genius Prestige Nnsd997s Inverter Microwave Oven 1200w Stain Questions & Answers
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Panasonic Genius... | Answered on May 07, 2018
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Panasonic Genius... | Answered on Sep 27, 2012
To erase a number from your blocked calls list;
Press  [MENU] [#] [2] [1] [7]
Press the [?] or the [?] button to select "Block a single number" or “Block range of numbers", press "SELECT"
Press [SELECT]Press the [?] or the [?] button to select the telephone number that you want to erase.
Press [ERASE]
Press the [?] or the [?] button to select [YES]
Press [SELECT]
Press [OFF]
To erase all blocked numbers;
Press  [MENU]
Press the [?] or the [?] button to select "Erase All", press "SELECT"
Press [SELECT]
Press [SELECT]
Press [OFF]
Panasonic... | Answered 3 days ago
H98 is no power to the magnetron. Usually caused by a failed magnetron or power supply failure.
Panasonic... | Answered on May 14, 2019
That depends...
It depends on how much the repair will cost and how long it will be before another repair is needed - these are unknown quantities but you could ask your local repair shop and a Panasonic dealer how much for a repair estimate.
Mostly if you go ahead with the repair the cost of the estimate will be waived. If you don't go ahead you should be able to negotiate the estimate cost as a discount off a replacement - if you use a Panasonic dealer.
10 years of hard work from a premium microwave should be as nothing when you consider my old Sharp Carousel lasted me 29 years of daily use, but then things today aren't built as well as they used to be.
I suggest you decide on the cost of a likely replacement model before you go ahead, follow the link below to begin your search. In the final analysis a repair is a bit like making a wager while buying new with a warranty is like putting your money on the favourite...
https://www.panasonic.com/ca/consumer/home-appliances/microwave-ovens.html
Panasonic... | Answered on May 13, 2019
In this manual it has a symbol for sensor cooking which will display when sensor is in use it looks like a dish with curved lines over it. Not sure if that is what you are talking about
manual belowhttps://www.winningappliances.com.au/public/manuals/Panasonic-NN-ST776SQPQ-44L-Inverter-Microwave-Oven-User-Manual.pdf
Panasonic... | Answered on May 05, 2019
Go to the Panasonic product support website for manuals.
Panasonic... | Answered on Apr 06, 2019
Panasonic Genius Prestige Nnsd997s Inverter Microwave Oven 1200w Stain Logo
16 questions posted
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Microwave Ovens
Most Popular Question
our microwaze shutting off after 25sec
  • Microwave Ovens
