Once connected to the ethernet cable you might have to press the tiny reset button on the back of either your gateway,router,modem of whichever service you have(Cable,DSL)
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
The HN9000 should have an ethernet port. You will require two ethernet cables to connect the desktop to the router.
1. Connect the ethernet cable from the Modem to the Ethernet Input port on the Router (It is generally placed away from the other ports on the back of the router.)
2. Connect another ethernet cord from one of the output ports on the router to the desktop computer.
3. On the laptop, turn on your wireless card. The process for this differs from computer to computer. If you were to provide the model of laptop, I could provide you specific instructions.
4. The network setup should be complete.
If you need more help, let me know by replying to this solution. Thank you for using FixYa!
You need an ADSL Modem & a Broadband connection. You run a cable from the Ethernet connection to the Modem/Router, and that connects to the telephone line, and then onto the internet.
Are you trying to hook up the laptop wirelessly to the pc? because then the pc would need to have a wireless card as well....sounds like I need more info, but if you are trying to do what I think you are, you should just get a wireless router instead, hook the pc tower directly to it via ethernet cable, and then setup the laptop to connect to the router. The router would hook to your dsl or cable router....what service do you have?
You need a router or a wireless router to do that. If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Hi. If Dell is correct, then yes, it would be expensive. Your other alternative is to buy a PCMCIA Ethernet Card. They range from about $20 to $40. Or, you could go with what you suggested and do wireless via a wireless router.
I want to help you out. I have some questions to ask you first:
1. What brand and model are your wireless router and laptop?
2. Does the laptop have a built-in wireless card or you installed one?
3. If it's has its built-in wireless card, check the wireless switch of the laptop. ICheck if it is on or off (some laptops sometimes has an on/off switch)
4. Check if the wireless light on your router is on (it's sometimes refered to "WLAN")
5. How many wired & wireless computers do you have and their operating system?
Your physical connections are correct. BTW, can you also specify what port from the modem is going to the router? Some routers have 1 port named "Internet or WAN" and 4 ports for "Ethernet." Check if the modem is connected to the "Internet or WAN" port.
There are 3 ways to connect to the internet. Using a modem with a phone line, an ethernet cable that is hooked up to a high speed internet connection or using wireless. If the laptop does not have a modem, it may have wireless or an ethernet port. Ethernet is slightly larger than a phone jack. If there is wireless there should be a button to turn it on and off somewhere along the top of the laptop where the keyboard is. You could also put get type of those connections on a PCMCIA card which fits into the credit card like slots on the side.
