The screen says paper jam, but I cannot find a jam anywhere. I can see that the paper roller is rolling, but it errors out right at that time. I'm not sure if it's because it's unable to pick up the paper, or if there's truly a paper jam hidden somewhere. I have removed all jobs from the pc, yet it still acts like its trying to print an old job. I've shut it off for awhile to see if that will reset and that hasn't worked either. I've also gone to the extent of removing the printer from the PC to see if that would force clear any jobs that I cannot get to clear myself. So far...nothing is working.
SOURCE: The Ricoh Alicio SP C410dn
You must first try to clean the paper feed roller which you will inside of the printer (bottom) when you pull out the paper tray. If this not works, then I am 100 % sure that the magnetic clutch which operates this feed roller must be replaced. I can tell you the part number for ricoh part catalog:
GX20-0014. If you don't have tech skills please don't do it by yourself because it's a hard and precision work. Call for help tech support
pifonski
SOURCE: hello my printer keeps getting jammed, it wants to
if it is in warranty , send back , and they will solve that problem.
