Ricoh Corp Aficio SP C231N Laser Printer Logo
A
Anonymous Posted on Jul 09, 2014
How to change feed roller on RICOH Aficio SP C242DN ?
Freckled legs
Level 2:
Habit-Forming:
Scholar:
  • Ricoh Expert 129 Answers
  • Posted on Sep 07, 2014
Freckled legs
Ricoh Expert
Level 2:
Habit-Forming:
Scholar:
Answers
129
Questions
0
Helped
105223
Points
252
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
1helpful
2answers
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Sc 542 code
fuser fault code. replace parts on fuser assy thermostat try first will need to reset code after parts replaced could be heater lamp or last board problem
Procedure 5810 error sc542
Dirty thermistor in fuser unit. Clean it and reset by entering SP Mode and then turning it off.
Reset error SC542
Because this is a fusing error and the fuser lamps use AC voltage, this repair is best left to a certified Ricoh tech.
Wouldn't want to start a fire.
How to change feed roller on RICOH Aficio SP C231N
You would need a technician to help out with the stuff.
2helpful
Need to reset maintenance count on a richo aficio AP410n laser printer ?
• After the technician replaces the fusing unit, the maintenance counter must be reset with engine SP mode 7-804. • 7-804-1: Transfer roller • 7-804-2: Paper feed roller • 7-804-3: Fusing unit).
How to replace maintenance kit; there were no instructions
fuser-
front door---raise 2 locks(levers)---pull out fuser
feed roller
remove paper fully--- under the printer move lever to the right and remove the feed roller(do not turn the printer upsidedown)
transfer roller --
front door--- press 2 green locks and pull unit out
1helpful
I have a SPC410DN Ricoh, it is having a problem feeding 110lb. paper in the upper bypass tray.it worked for years and now its giving me a fit!
is it not pulling or double feeding? most likely it is the rollers in the bypass. most mnfs it is the sep roller (bottom of 3) that gets worn causing multiple feeding. if it won't pull it is the FR (furthest back of the upper two rollers)
Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
