We have a brand new 55'' vizio LCD TV that when we turn on it has a whistling sound it stays on when tv is on but stops when I turn if off. Just purchsed TV yesterday. What could it be?
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on. If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
SOURCE: I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
SOURCE: I can get a 55-inch
I just casually looked at the TV in Menards the other day and the picture quality didn't look very good to me. To confirm my suspicions, I did a little searching. Conclusion: keep shopping
http://other-company.pissedconsumer.com/bait-and-switch-of-auria-tv-20110227224052.html
http://slickdeals.net/forums/showthread.php?t=2663641
http://www.viewpoints.com/Auria-Auria-Model-EQ5588-review-a6a511
