I have a vizeo smart 55 inch flat screen tv that would not turn on, replaced all boards now it turns on but no video.i have sound and very clear still pictures.also there are vertical lines on the screen in color
When you say clear pictures are you talking about the menu works?
Posted on Jan 14, 2023
It sounds like you may have a problem with the video signal on your Vizio 55 inch flat screen TV. The fact that the TV turns on and has sound, but no video and vertical lines on the screen, suggests that there may be an issue with the video processing or display.
It could be a problem with the T-CON board, which is responsible for the video signal processing. It could also be a problem with the LCD panel itself.
It's also possible that there's an issue with the cable connecting the T-CON board to the LCD panel, or a problem with the software on the main board.
I recommend consulting the manual of the TV or contacting the manufacturer for further assistance. A professional technician should be able to diagnose and fix the problem.
It's also possible that the issue is with the mainboard or the T-CON board is not compatible with the TV. Thus, it's best to check the compatibility of the parts with the TV before installing it.
Posted on Jan 13, 2023
