Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L LCD TV screen black when turn TV on first time
Three month ago I bought a Vizio GV42L LCD TV, from first day when turn on the TV, the audio is fine but the picture (screen) is black, when I re-start TV all is fine (Audio and video works well). This happen after the TV is off for a long period such as 4 hours.
Posted by Elkin Ospina on
  • 4 more comments
  • kimber224 Mar 10, 2008
    Purchased a vizeo tv about 5 months ago. There is a black box that appears in lower right hand corner....how to get rid of this?
  • Mac2122 May 02, 2008
  • Anonymous Mar 13, 2014
    I turn on the tv and it comes up fine, then suddenly the screen goes black but I still have audio. If I turn it off and back on it will come back on but repeatedly the screen goes black. What do I do to fix this?
  • Anonymous Mar 19, 2014
    if you turn off and on numerous times it will finally come on
    has beautiful picture what else should i check
  • Anonymous Mar 20, 2014
    My vizio LCD tv started flickering and soon after lost all picture. backlights are still working but scree is black
Anonymous
I have 42 inch LCD, where do you buy the inverters
Posted on Nov 04, 2008
Anonymous
VIZIO 47" GALLEVIA WORKED PERFECT FOR 4 MONTHS .IT IS THE (MASTER)* BACKLIGHT INVERTER* FOR THE PEOPLE WITH THE VIZIO 47 INCH. ACTUALLY I SWAPPED MINE OUT (BACKLIGHT INVERTER)AND IT WORKED PERFECT.WHEN IT FIRST STARTED ACTING UP I HAD VIDEO AND AUDIO FOR A FEW HOURS THEN THE VIDEO WOULD JUST GO OUT BUT THE TV STILL PLAYED AND THE SOUND WAS THERE BUT NO PICTURE.The defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing inverter will solve the problem.
Posted on Sep 06, 2008
Dewayne Turner
  • 87 Answers
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
2 Related Answers
zap5732
SOURCE: GV42L
I had this same problem. Vizio sent someone out to replace the motherboard. It didn't fix the problem. Since it was under warranty, they replaced it with a newer model VU42L. Doesn't have this problem, but it has others.
Posted on May 06, 2008
Anonymous
  • 207 Answers
SOURCE: Vizio GV42L
Call vizio asap they will have a tech come and fix it free.. after the manufacture warrenty runs out they want to charge you 6--$ to fix it here is the number! 877 698 4946
Posted on May 29, 2008
I have a Vizio VW42LFHDTV10A -- The first time I
Please check for bad electrolytic capacitors on both main board & power supply, if there is any "pup-up" one, replace it (them).
Aug 15, 2017 | Vizio GV42L 42 in. LCD Television
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Vizio 42" LCD screen is red where is should be black. It's only 3 months old!
It maybe a video board or LCD screen control problem. Best to use the warranty at this point. You shouldn't have to pay a dime for the TV breaking down this early.
Here's a link to help you get started on your warranty:
http://www.vizio.com/support/
Sep 09, 2009 | Vizio GV42L 42 in. LCD Television
No pic no sound
your TV was overheat. check secondary power supply inside chasis. check all the components specially thus budged capacitos.
Jun 03, 2009 | Vizio GV42L 42 in. LCD Television
22in vizio will not turn on
bad power supply board or mainboard
Nov 10, 2008 | Vizio GV42L 42 in. LCD Television
Vizio GV42L
May 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
GV42L
May 02, 2008 | Vizio GV42L 42 in. LCD Television
TV Will Not Start Occasionally
Sounds like this unit is still in warranty. Have the service people come out and look at it. If you don't have a bill of sale, you should still have production dates on the unit.
Jan 23, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio P2 42 in. HD-Ready Plasma Television Logo
Top Vizio Televison & Video Experts
Paul Bade
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
