Royal 500DX CASH REGISTER Logo
S
SABINA ENGELKEN Posted on Dec 14, 2013
RUN A Z READING - Royal 500DX CASH REGISTER
I have DCA analyzer from Siemens healthcare and i have problem E24 ,How Can Solve it
Manual is available in PDF format from here
http://docslide.us/download/link/dca-operators-guide
http://docslide.us/download/document/?id=%2FJKJQj2KkZIjS9Tn4Jm5CAbRibVv%2BGl%2BT9wi7I03ZyGSjZf8c1bXQnPy2%2FSc3BFIu8t3mvccp4VXj23OQyX8pQ%3D%3D
DCA Vantage Operator's Guide 109
Troubleshooting
E22 - Optical
reading is out
of range
A Sample or Reference
channel reading taken
during an Air
measurement is too
high.
1. Discard the sample.
2. Run an optical test.
3. If you are unable to run an
optical test, contact your local
technical support provider.
E23 -
Excessive
noise on the
Sample
channel
The standard deviation
of the 16 readings at the
Sample channel for Dark
or Air reading is too
large.
E24 -
Excessive
noise on the
Reference
channel
Reference channel for
Dark, Air or Sample
reading is too large.
E26 -
Excessive
noise in sample
reading
Sample channel during a
reading taken is too
large in Sample read
position.
E27 -
Excessive
Lamp Drift
The change in mean
signal between
successive Air readings
is too large at either the
Sample channel or the
Reference channel.
E30 - Thermal
control system
error - low
The temperature
measured by one of the
cartridge holder
thermistors is ?2?C.
2. Restart the system.
3. If you are unable to perform a
successful restart, contact
your local technical support
provider.
E
tip
Pins on the compressor.
<img src="walterkunesk.gif" />If you have an ohm meter you can test the compressor in your equipment. There are three pins on the compressor. Start, Run and Common. The common pin is the pin that is by itself while two are either above it or below it. <br /> First thing to do is check for grounds. From compressor body or tubing to each pins seperatly, You should get no reading on the pins to ground. Now that you have done this, you can check each winding for open, and check the resistance on each winding. With you meter one leg on common and you can pic any one that is left, it will only be either the start winding or the run winding. Measure the resistance and write it down, If you get no reading, the compressor is scrap due to open winding. Then go to the next pin and check it for open if you get a reading right it down. Between the two numbers that you have the comon and whatever pin has the lowest reading is the run winding. The pin with the highest reading is start winding. Now add these two numbers together and take your meter and measure pins start and run, they should equal the two numbers that you wrote down, hope this helps. A rating would be cool.<br />
on Oct 24, 2011 • Refrigerators
Motor doesnt start
1st check for proper voltage across the terminals , no reading means no power exists or bad switch, if not ohm the motors windings and compare the run and starts readings combined equal the reading from run to start terminals, if so the run capacitors likely bad, or start cap too if equipped.
What are the ohm reading, and voltage reading on the evap motor?
Ohm reading is the resistance value of the motor windings. This is a small capacity motor so it's winding resistance will be high. Somewhere around 180 to 350 ohms.
Voltage reading is the electrical pressure that the motor winding can withstand. If the voltage of the source exceeds that of the motor rating than the windings will burst ( burning out the motor) If the source is less than the voltage rating of the motor then the motor will run too slow.
Checked the compressor terminals the 2 highest read 9.3 while the other 2 read 6.4 and 3.0. Is my compressror bad?
most likely not, but you also need to check from terminal to ground. If you get any reading at all, the compressor is most likely grounded/ bad. Be sure to disconnect all elelctical to unit and all component to compressor.
3 terminals are Start, Run, and Common. Take a reading from common to Start, then common to run.
Add those numbers. Now take a reading from start to run. The totaled numbers should be very close to the run to start numbers. Your numbers look good.
what seems to be the issue? If it is not running, be sure it is getting power and all start components are good. This is usually the most common problem.
Codes are reading cylinder misfire and replaced
does the check engine light come on b 4 or after
Loads dvd tries reading ejects dvd
Run DVD/CD cleaner CD using 2 drops of solvent on the brushes and run the cleaner CD twice, the last one being a dry one. If the DVD's are not scratched they will definitely play....sodeep
Top Royal Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
