20 Most Recent Royal Sc120 Shredder Questions & Answers
NEED
TO CLEAR MY SHREDDER CROSSCUT ITS STUCK HELP ASAP
Royal Sc120... | Answered on Jun 27, 2013
In order to maintain a functional paper shredder, you should clean it out and oil it at least once a month(depending on usage) if not every time you fill it.
I would advise against trying to disassemble the actual blades to clean them out if that's what you mean by "take it apart."
What you can do is unplug the machine, lay the blades up and get a pair of tweezers and remove any large pieces of paper/shredding that might be caught in there.
After doing that you should oil the blades with any lubricant that your owner's manual recommends.
Most shredders suggest a non-aerosol/biodegradable oil such as vegetable oil.
Do not use WD-40 or other canned spray lubricants.
I've found that dripping the oil straight into the blades can be very messy so a good alternative is to lay out a piece or two of scrap paper and soak it in the oil. Then run the paper through the blades as normal.
They also sell varieties of this here: http://www.staples.com/Staples-Shredder-Lubricant-Sheets-12-pk-Shredder-Sheets/product_602400
It doesn't have to be a headache to maintain but proper care can make your shredder last a long time.
Royal Sc120... | Answered on Jan 18, 2013
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Royal Sc120... | Answered on Feb 21, 2012
Shredders have a reputation for being very unreliable...they often just quit like that...
You can try also to blow it out with a can of compressed air, but it probably won't help... not much else that you can do...
heatman101
Royal Sc120... | Answered on May 27, 2011
Sounds most likely that you dont have the waste bin back in properly...do a double check there.
Royal Sc120... | Answered on Feb 16, 2011
Give Royal a call at 1-800-524-0799 for parts assistance.
Royal Sc120... | Answered on Feb 09, 2011
You will have to open it up to look inside ...it sounds like something/wire is off-loose or is shorting out somewhere.
Royal Sc120... | Answered on Jan 16, 2011
Royal Sc120 Shredder Logo
19 questions posted
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Royal Office Equipment & Supplies
Most Popular Question
shredder squeaks when in use need
  • Office Equipment & Supplies
