During printing, the HP product makes unusual or loud noises. You might
describe the noise as grinding, squeaking, or screeching.
Step one: Clean the rollers in the back of the product
Disconnect the power cord from the back of the product.
On the back of the product, find the rear door.
Squeeze the tab or tabs on the rear door, and then pull the rear door toward you to remove it.
Open the rear door on newer Photosmart, Officejet, or PSC productsInside the back of the product, rotate the paper rollers with your fingers to make sure that they can turn freely.
Rotate the rollers located on the inside of the rear door to make sure that they can turn freely.
Remove any torn pieces or scraps of paper that you can see.
Dampen
a clean, lint-free cloth or swab with distilled water, and then wipe
the paper rollers inside the product and on the inside of the rear door
clean. Rotate the paper rollers with your fingers to clean all the way
around them.
Reattach the rear door. Make sure that it snaps into place.
Step two: Clean the rollers in the front of the product
Lift the cartridge access door to access the front paper rollers in the product. NOTE:On
some Officejet models, you might need to close the document catcher.
Then, look in through the front of the product to access the front paper
rollers.
Inside the front of the product, rotate the paper rollers with your fingers to make sure that they can turn freely.
Dampen
the paper rollers clean. Rotate the paper rollers with your fingers to
clean all the way around them.
Step three: Clean the small rollersDampen
the small rollers, also called the pinch rollers, clean. The pinch
rollers are the small metal rollers directly above the paper rollers.
Rotate the pinch rollers with your fingers to clean all the way around
them. NOTE:Do
not clean the carriage rod. Removing or damaging the lubrication on the
carriage rod can cause the product to make more noise.Figure 9: Carriage rodStep four: Clean the cartridges
Connect the power cord to the back of the product, and then press the Power button (
) to turn on the product.
Open the cartridge access door.Figure 11: Lift the cartridge access door on newer Officejet, Photosmart, and PSC products
When the carriage stops moving, disconnect the power cord from the back of the product.
Press down on each cartridge to release it from the carriage, and then pull it toward you out of its slot.
NOTE:
You might need to lift a cartridge latch before you can remove the cartridge from the product.
1 - Tri-color cartridge2 - Black cartridge
Dampen
any ink or debris from the copper-colored electrical contacts on the
cartridge.
CAUTION:
Do
not touch the ink nozzles or the electrical contacts with your fingers.
This can result in clogs, ink failure, and bad electrical connections.
Figure 13: Clean the copper-colored electrical contacts1 - Electrical contacts2 - Ink nozzlesFigure 14: Do not touch the copper-colored electrical contacts or the ink nozzlesPlace the cartridges on a clean sheet of paper, with the nozzles facing up.
Step five: Clean the electrical contacts inside the product
Dampen
any ink or debris from the electrical contacts inside the carriage
Let the cartridges and carriage sit for 10 minutes to allow them to dry, or use a clean, dry swab to dry the contacts.
Slide
each cartridge into its slot at a slight upward angle, and then press
firmly until you hear the cartridge click into place.
Install the tri-color cartridge in the slot on the left.
Install the black cartridge in the slot on the right.
I have seen this before but it has not caused the black to run out quickly. if you look into the machine you will see at one end of the platen roller it will be swimming in ink. As the paper passes over the roller it will deposit ink to the back of the paper. now why is the ink getting there? Well its just possible that air hole in the cartridge is blocked but you say you have replaced the cartridge. Ah but with what? are you using recycled cartridges? they may be filled with ink and not dye which is what originals use. Dye is much thicker than ink and ink maybe leaking from the cartridge. The seal in the carriage may not be making a clean contact with the base of the black cartridge causing it to leak when the carriage is moving. Check those out and repost if still having the problem. Good luck
black vertical lines on the printout comes due to some reasons.
1) if the black cartridge is near to its end it will give black lines instead of proper printing.
the cartridges gets over many times due to head cleaning and deep cleaning.in 3-4 cleanings cartridge gets over.in one cleaning 4 ml of ink gets puled out of cartridge.the whole quantity of cartridge is near to 25 ml.
but if the cartridge is full then the problem is of cartridge head .the head is the part in which you insert the cartridges if the head is got blocked internally to its holes from where ink comes out.then there are two methods to clean the head one is head cleaning which you did.the other is removing the head by disassembling the printer and then cleaning the head manually with isoprophyll liquid.but its a time consuming and tough job.a local printer repair center will be advisable,
and in some cases it has seen that cartridge gets air pressure problem inside and due to that it leaks inside the printer so replacing that cartridge solves the problem.also many times the cartridge gets leaked and that leaked ink gets collected and stuck up on the roller of the printer from where paper passes so the strips of ink gets printed on the paper.in this case no head cleaning but cleaning the internal roller of the printer with tissue paper helps.the procedure is called servicing.that can also be done at local printer repair center.or you can do it manually by using tissue paper.but to service whole printer it needs to be disassemble.
check out his option.thanks.
It means ink is backing up on the rollers, it is waste ink and should be going to the absorber, but some models have the ink drying up and plugging the passages. You will need cleaning, new ink absorbers, and a mylar strip that will keep that from happening in the future.
The roller cleaning will require you to remove cover to clean the full roller with alcohol to remove ink build up. Have you tried to just run/feed a blank piece of paper through to see if you have roller ink roll off?
This also sounds like a bad cartridge with clogged jets...
Hi , clean both end of roller clean rug or cotton tip , this may happen during cleaning time some ink expose both end of roller sometime in piece of paper .during the cartridge in the middlle pullout the power cord stop cartridge and push cartidge down and lock.
