I have three receivers only one has complete signal loss. check switch gives error 836.
SOURCE: loosing program on 311 receivers every other day
a phoneline is not going to effect your programming at all, do you see an error message when this happens??
SOURCE: nearby TV is not working - no picture. We tried to
It may be that your dish has been blown out of alignment or struck by something resulting in the misalignment. The dish will need to be repointed. Please call Dish for a service call to rectify the issue. Thanks for using Fix Ya.
SOURCE: receiver 510 error code 836
err 836 means you have changed your recvr to a different dish or LNB's or your missing one or more satellites needed for your installation or programming needs. if this has been in the same location and connected tot he same dish and you dont have sats 105,or 121 listed in the install summary then you will need a technician to check your dish. It could be out of alignment or a faulty LNB.
SOURCE: i have dishnet receiver dp301 i have no signal i
Does it gives you an error message after a check switch?
Hi edhayes27 my name is Mike Houston of DISH Network Executive Office. This posting in FixYa shows you have the 311 receiver; this receiver will only show SD channels. We do have the VIP 211 which will show in HD and SD channels. If possible can you verify the model number of your receiver, which indicates you
