Question about DISH Network Vip 211k High Definition Receiver
No matter what I do I can not get any signal. When I do test it shows no signal very frustrated
Posted by prodriver46 on
NickF DISH
    New Friend:
  • 36 Answers
Hi prodriver46,
Are you receiving any error messages on the screen? Usually with signal loss it would be error 015 or 002. I would suggest during a hard reset with the receiver by unplugging it from the wall for 10-15 seconds and allowing it to reboot once plugged back in. If the problem persists run a check switch test by hitting menu on the remote followed by 6-1-1. If you receive any error messages after the check switch we will have to send a technician out to correct the issue. Feel free to e-mail me at [email protected] with any further questions or concerns!
Nick Franta
DISH Network
Posted on Apr 27, 2011
Installing aftermarket turn signals on a Suzuki 1978 gs1000. Windjammer fairing removed so I have no wiring reference for turn signals. Need a wiring diagram, or just a simple explanation. PLEASE help....
Get a test light. Hook clip on - side of battery. Turn on turn signals and ck wires. The light will flash, that is the + wire. If turn signal has only 1 wire hook that to the + wire. The - connection will ground through frame and complete the connection.
Apr 30, 2014 | 1978 Suzuki GS 750 E
"no signal" shows up on
You will need solid coax ends and connects. You need very high grade coax union and snap and seal coax BNC connectors for both ends.You also need a RFI filtered surge protector to filter all the AC plugs for the HDMI box. This shoulf fix your problem
Aug 07, 2011 | SunBriteTV 4600HD TV
My Sigma wireless dts 1606 L is not getting a consistent signal between the transmitter and the receiver. For example to day I rode 60 kms and the computer only worked / received 2kms worth of signal -...
It's a matter of good line of sight and distance between the transmitter and the receiver. Yours may be on the hairy edge of too far. Remove the receiver and test it at various proximities to the spinning wheel when it's transmitting.
May 22, 2011 | Sigma Sport BC1106 Dts Wireless Bike...
I have a Cobra ltd 25 classic in my pick up. the cb will turn on but i cant get any stacik no matter where i turn the squelch or rf gain. this doesnt seem right because it has never done that before. but...
Does the signal meter show any signal? Try plugging something into and out of the EXT Speaker jack to see if maybe that is preventing the internal speaker from working, or plug in an external speaker or headphone to test it. If the meter shows nothing, I'm concerned about your electronics, especially with the 'squelch' control 'wide-open'. 73's
Aug 13, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Futura ce-100 embroidering in the wrong place
I decided to simply start from the beginning and start all over. I turned off the machine, detached the embroidery unit and blew into the sensor (where the machine and embroidery unit connect). I'm not sure what the problem was, but it was fine after that! Just goes to show that no matter how frustrating things can be, it pays to just take a moment and start over!!
Feb 18, 2009 | Singer CE-100 Futura Computerized Sewing...
Display show ANT Test Mode...will not respond to anything
I did not solve the problem....it sort of just solved itself which is still extremely aggravating. Don't get me wrong, I am happy it is now working for the most part but to spend this kind of money and have it not work all the time is frustrating. This is not the first time I have encountered issues but I am generally able to reset it on my own. This last issue was just so bizzare that I cannot even begin to tell you all of the things the just popped up on the screen without me even touching it. At one point, it showed ANT Test Off, then it showed a huge X across the screen. Another time it simply read -1.00. After it was done displaying these random bits of data, I tried to reset one last time and had success. However, the data is not uploading to Garmin/connect. So my frustration continues.
Aug 06, 2008 | Garmin Forerunner 405 Handheld GPS...
Samsung DVD-VR357 Won't play ANY DVD's
I have the same problem. How do you reset the unit?
Jan 09, 2008 | Samsung DVD-VR357
Used phone many problems
Contact your network provider. They can test the signal of the phone and also reset it to the network settings. Have you turned your phone off recently? Leaving a phone on continually will sometimes give you these errors. The network updates the software in your phone and if you do not turn it off once in a while the updates will not be applied.
Sep 18, 2007 | LG CU500 Cellular Phone
DISH Network Vip 211k High Definition Receiver Logo
929 people viewed this question
Top DISH Network Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a DISH Network Home Security Expert? Answer questions, earn points and help others
