Samsung WA50F9A8DSP Platinum 5.0 cu. ft. High-Efficiency Top Load Washer WA50F9A8DS Logo
L
Lukas Guennel Posted on Oct 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What should i do? It continues to add time and cycles?
gerbee gomez
Level 2:
Novelist:
  • Expert 222 Answers
  • Posted on Nov 02, 2013
gerbee gomez
Expert
Level 2:
Novelist:
Answers
222
Questions
0
Helped
139322
Points
388
Just press the botton of each cycle want u want,like add rinse press rinse botton and it will add rinse,press spin botton it will add spin,but for washing,cant coz already set the time,default program for wash and cannot change
1helpful
2answers
I have bought a second hand dishwasher WQP12-HFM ME and I am not sure how to use it?
Sometimes a dishwasher will run for hours especially new ones. Newer dishwashers use very little water but run much longer. There are some things you can do to shorten the time. Turn off the options. These extras will add time to the cycle. Sani rinse, Heavy wash, Hi temp, Pot and pans, Tough cycle. If you have a normal load of dirty dishes it’s unnecessary to add options. A normal load without extras can take 3 or 4 hours alone.
Sep 19, 2022 • Dishwashers
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
MY KITCHENAID DISHWASHER FAILS TO POWER OFF
Programmer fault.......time for repair man or replace machine. I assume out of warranty.
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
2003 Ford Focus A/C cycles on and off rapidly
It is low on refrigerant. You probably let air into the system and didn't add much . Take it to someone licenced to work on A/C. You got a leak to be repaired or you wouldn't need to add to it.
1helpful
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
21helpful
3answers
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
