20 Most Recent Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer Questions & Answers
Faulty or worn drain pump,
Regards
Phillip
Samsung 4.3 cu.... | Answered on May 10, 2016
The main PCB has failed and will need to be replaced. Best to call your local appliance technician for this one.
Samsung 4.3 cu.... | Answered on Nov 08, 2015
The dispenser is purged to eliminate residue.
Samsung 4.3 cu.... | Answered on Oct 25, 2015
Hi there
When using liquid bleach, add to compartment "Liquid Bleach"
and when using powdered bleach, it is recommended to add directly to the drum making sure the powdered bleach entered in to the hole of the drum, then add laundry.
Detergent and fabric softener added to the relevant compartments.
When using powdered detergent, remove the liquid detergent holder from the detergent compartment.
All of the compartments are housed in the detergent drawer top left of the washer.
I hope this helps
Kind regards
Phillip
Samsung 4.3 cu.... | Answered on Apr 17, 2015
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Samsung 4.3 cu.... | Answered on Mar 26, 2015
Hi
Are there any error codes on the display
Regards
Phillip
The latch is either broken or has come loose. Check the latch to see if either applies.
Samsung 4.3 cu.... | Answered on Jan 03, 2015
The drain pump is not something that you can simply "reset". If the overload device has operated "open circuited" and has not reset itself after cooling down, it will have to be replaced. It is located between the motor coil and iron. However, if this is the case, it may mean that you have a serious problem with your motor. And to make matters worse, if you have a problem with your drain motor, it may cause problems in your Control Panel.
Samsung 4.3 cu.... | Answered on Dec 17, 2014
the soap, bleach and fabric softner get dispensed by opening a water valve to the dispenser to flush out the items. They then flow to the bottom of the tub. Not all of the water comes out for various reasons, but the important information is that it is seldom critical to performance. If you want to pursue it, check dispenser (take it out) and clean it well. I assume the machine is level.
Samsung 4.3 cu.... | Answered on Oct 20, 2014
CALL: (517) 489-1566 I CAN COME AND DIAGNOSE THE PROBLEM FOR YOU
Samsung 4.3 cu.... | Answered on Oct 19, 2014
Try unplugging it for about a minute and then plug it in. That may reset the computer.
Samsung 4.3 cu.... | Answered on Oct 04, 2014
Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer Logo
59 questions posted
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
washer no power panel will not turn all
  • Washing Machines
