20 Most Recent
Samsung WF337AAL Front Load Washer Questions & Answers
4E showing on Samsung Washing Machine
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
We have a Samsung front
Is the display (User interface) is lighting up and on. That means you are getting power.
If display on and cycle stopping at mid cycle and cannot open door.
If the machine water level sensor detects sufficient water in the machine it will tell the control board not to release the door.
Is there is water in the machine. May be your drain pump is clogged. Does it give a error code on display.
Don't force open the door. You will break the lock and you will need $ 200/= parts and labor to change the door lock
Call a local service guy
NF error code during rinse cycle only.
If the unit was working fine before bearing repair, then I lean toward wiring issue. Do a visual inspection of the water valve and all the wires to it. One might have been put in wrong place. If wiring is correct, then maybe a bad water valve. The water valve has multiple solenoids and the one for rinse might be bad. I still think its a wiring issue. Good Luck!
Wont drain
Following will be the causes
There is a motor/Pump which operates to to drain the water check whether that motor is working.
Check filter and clean it
Check the drain pipeline whether it clear
Check the inlet valve of the machine Sometimes the drain works properly but the inlet solenoid valve will not hold and the water keeps coming in and fills the drum
Thank You
The fabric softner cup will not drain
I don't know the solution to this either. Both my Whirlpool, front load washers: old one (15years old) and new one (2 months), the softner itself is always drained into the wash and residual water is there at the end of each wash.
Disadvantages of washing machine
For replacement parts - head on over to PartSelect.com or
RepairClinic.com and enter in your full model number for a full parts
listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your
unit and great "testimonials" for each part that often times includes
HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original
service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a
step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^&^
Water is streaming out of
Check for blockage into tub from inside at inlet and underneath drawer if you use powder detergent old detergent may clump and block line into tub.
The fabric softener dispenser works by time and water flow from the cold water inlet valve . Check the screen on your cold water inlet. If clean, the water inlet valve may need to be replaced. Take a look at the cold water inlet valve that has the rubber tubing running to the "bleach" dispenser nipple. It will have a water flow restrictor in it at the inlet valve. Something may partially clog the flow restrictor. Carefully drilled the valve out enough to remove the clogging object. Now both the bleach dispenser and fabric softener dispenser work properly and at the correct times during the wash.
Thanks for contacting fixya.com
