SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
SOURCE: Frond load washer Frigidare ES1
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 you need to replace door lock..
hope it helps
SOURCE: Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
SOURCE: Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
