This shut off fan runs a bathroom fan. It worked fine for a while but now only runs about 10 seconds, no matter setting. For example, set at 10 minutes, it runs for 10 seconds then shuts off. Set for 20 minutes, it runs for 10 seconds, drops to the 10 minute setting, runs for another 10 seconds, then shuts off. Can this be fixed?
Buy another timer:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: ei210 in wall countdown timer in undocumented ''test mode''?
You could try disconnecting power to the switch for a few minutes maybe that will reset it. Other than that I would say cut your losses and replace it. Hope this helps a little.
SOURCE: Can the Intermatic El210 be set to turn things on and off?
You will need a more sophisticated timer than most hardware stores carry. Go to Smarthome.com and click their timers and automation section. There you will find many levels of sophistication in timers. good luck
SOURCE: Malibu Low Voltage Outdoor 300-Watt
How many watts of lights are connected to the transformer. It should be between 250 and 300 watts.
Gary
SOURCE: how to set my grasslin
Open following link for setting Intermatic/Grasslin FM1 timer setting instructions:
To set the 24-hour analog timer, you need to move 4 consecutive tripper pins for each hour of run time.
So for 6 am to 6 pm, 48 trippers pins will be moved outward and 48 inward.
http://waterheatertimer.org/pdf/How-to-set-Intermatic-FM1-timers.pdf
Open following link for Intermatic FM1 series and PB series modular timers with wiring, manuals, model numbers and instructions for setting.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
