.... if it was sewing fine before the bit 'dropped off' it probably doesnt need the other thing done - they just are standard type check / adjust things done with a service. Weigh up how much a new machine will cost you v the repair. How happy are you with it? How often do you use it?
I am not familiar with this model, but the 'clutch' is generally a very simple setup. If you feel confident and can get the end cover off , have a peek - find the bit that dropped off ......
The only tension you should need to adjust is the bobbin tension - which I am sure you already know how to. Top tension is normally just a clean out of fluff etc.
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
SOURCE: Consew CP206-R Stopped Sewing/Working
Hi there, please send me an email and I will send you the mechanics book for your machine.
Kindest Regards,
Richard.
[email protected]
SOURCE: Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions [email protected]
SOURCE: Bobbin won't wind. Machine
Hi, take the top of the machine cover off by removing screws on top plastic cover. Make sure that the rubber ring on the wheel that turns the bobbin threader is making contact with the belt from the flywheel in the back. You may need to see if it turns freely. If not take it off and lubricate it until it frees up and then replace it and the cover.
SOURCE: Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
