If your Canon IR 2520 copier is showing a "paper jam" error message when powering on, but there is no paper in the fuser, it could be caused by a few different things:
A sensor problem: The copier may have a malfunctioning sensor that incorrectly detects a paper jam in the fuser. This sensor might need to be cleaned or replaced.
Wiring issue: There may be a problem with the wiring that connects the sensor to the main circuit board. A broken wire or loose connection could be causing the sensor to malfunction.
Software issue: The copier's software may have a bug causing it to display the "paper jam" error message even when there is no paper in the fuser.
Mechanical problem: The fuser assembly may have a mechanical issue, such as a jammed gear or roller preventing the copier from correctly sensing that there is no paper in the fuser.
It is best to have a professional technician diagnose the issue. They will be able to identify the specific cause of the problem and make the necessary repairs.
It's also important to check the owner's manual for troubleshooting options or error codes that might be displayed on the copier.
If the copier is still under warranty, it is recommended to contact the manufacturer for service.
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can... Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
You need not to pannic.Those paper jams are always there... What you need to do is to check you paper arrangement in papers tray sometime rough arrange may led to paper jams everytime
hi;
its a fixing film problem, your fixing film is not spining properly maybe its paper jammed inside try to clean paper jam carefully else you order new fixing film from canon
good luck
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
