20 Most Recent
Canon ImageRunner 3025 Black and White Copier Questions & Answers
WHAT IS CANON ERROR CODE E000202-0002
Hi
My normal first step is to turn off any machine that exhibits a problem, and any other machinery to which it is connected eg a computer network etc. Leave it for about 10 minutes ad then restart it. This is sometimes sufficient to clear errors and reset the machine to an operating condition.
If this doesn't work I look elsewhere and in your case found a description of your error here:
Error Codes Canon iR3025 Code E202 0002
Also on this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page and you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
2/4/2019 10:47:32 AM •
Canon...
Answered
on Feb 04, 2019
E000020-0000
E000020 waste toner is not flow, open up all of unit drum with detail. check the black n long screw of plastic.
4/15/2018 3:10:33 PM •
Canon...
Answered
on Apr 15, 2018
Copier insists there is a paper jam when there isn't.
ok have dealt with this a ton at my old job and found that if you take out all trays toner packs anything that is made to be removed then do a quick check for any paper jams or even small bits of paper that may be stuck and remove it all then put everything back together it usually fixes the issue. If that does not work then a reset of the machine may be in order simple turn power off and back on. you can hold the power button in til it shuts off or simple unplug it leave it off for about 15 seconds then turn on and check again if that doesnt help i dont know .
5/12/2015 4:23:57 PM •
Canon...
Answered
on May 12, 2015
How do I fix error code E000007-0000
The fixing film assembly needs to be changed. The film will be torn on one end causing the film to track to one side causing the e007.
2/19/2015 3:21:12 PM •
Canon...
Answered
on Feb 19, 2015
How to install cannon imase runner 3025N
Mirriam, what part of the install has you stumped? Print drivers? Scanning? Hardware assembly? I need more information so I can try to help.
Thank you,
Andy
11/25/2014 4:35:58 PM •
Canon...
Answered
on Nov 25, 2014
How to shutdown photocopy ir3025
The proper way to shutdown the machine is to press and hold the Power button in Control Panel for 3 seconds and wait for the shutdown instruction displayed. And turn off the main power switch located at the lower right side portion of the machine.
1/10/2014 9:02:27 AM •
Canon...
Answered
on Jan 10, 2014
How to shut down photocopy ir3025
push and hold the gray on/off button on the control panel. It will eventually ask if you would like to shutdown, select yes. It may say shut off by itself or say to shut main power off. The main power switch is on the right side toward the back and down. Flip the switch.
1/9/2014 1:05:25 PM •
Canon...
Answered
on Jan 09, 2014
