What is remedy error code E000007-0000 for canon imageRUNNER 2422/2420
When i start the machine the scanning senser getting stuck and messege call service rep appear with E000007-0000
Posted by MONDAY KALIMBANYA on
  • lin ag May 21, 2017
    canon ir 2420l
    restart the machine.If problem persists.Call service rep.
    **E000007-0000
Chris Coughlin
  • 1,326 Answers
A E000007-0000 means that the fixing film is out of "HP" The fixing film has a white patch that is the home position and as the film is turned, there is a sensor that reads it in & out of "HP". Odds are that the film is ripped on one side and the film moved toward the front of the copier and the sensor can not read the patch. You will need to replace the upper film unit or the whole fuser unit to repair the problem.... Good Luck
Posted on Sep 27, 2012
  • Mukut Bhuyan
    Mukut Bhuyan Jan 21, 2015
    error msg E000007-0000
Ahmed Seid
    New Friend:
Canon 2420 image runner restart the machine if the problem persists call service rep
**E000261-0000
Posted on Aug 30, 2013
  • Leul Seged Oct 29, 2013
    chage the fuser film
Francis Phin
    New Friend:
Change the teflon cover in the fixing unit,
Posted on Dec 12, 2012
BritishEmpire Belaynian
Just replace the Fusser film or proprely plug the socket or small jack under fusser film to one side or head unit
Posted on Mar 26, 2020
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Canon D861 copier
Garner,,, the C000 code is a fuser error code on this machine. It can "sometimes" pop up after a power surge/spike/loss event, and needs to be reset in service technician mode. If it doesn't reset, but rather comes back, you probably need a sevice call for something defective in the fuser (lamp, fuse, thermister).
IF YOU'RE GAME, here it is...
To enter service simulation: press"Additional Functions" to enter "User mode". Press # key. Press </> to select a menu item. enter new data using number keys. Press "Set/OK" key. Press Stop/additional functions to exit.
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET."  Power the unit off/on.
Posted on Oct 12, 2007
Anonymous
SOURCE: error EOOO ir 2000
System error E000
Posted on Aug 03, 2009
Anonymous
  • 25 Answers
SOURCE: Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Posted on Feb 13, 2010
Anonymous
  • 57 Answers
SOURCE: Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Posted on Sep 03, 2009
Anonymous
  • 38 Answers
SOURCE: Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Posted on May 08, 2008
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
Error E 354
Description
System error
Remedy
Contact to the sales companies.
Apr 01, 2014 | Canon imageRUNNER 1023iF Black and White...
How do you fix error code e000025-0320 on a canon c7260
You need to clean the Meg toner senser. remove front cover under the toners, second senser from the left.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Canon Printer Support
Feb 27, 2014 | Canon imageRUNNER 5570 Copier
Need help imageRUNNER 2422/2420 fail to run the scanning senser getting stuck giving error code E000007-000
MODEL NO. : IMAGE RUNNER 2422/2420
NO WORK SCAN. WHEN I PRESS "SCAN" BUTTON SHOW "THIS FUN. REQUIRES OPTIONAL EQUIPMENT" IN DISPLAY BOX. PLEASE HELP ME HOW TO SETTING AND SOLUTION THIS MACHINE. SO HOW TO SCAN FRO PC AND SETTING? THANK YOU
Sep 18, 2012 | Office Equipment & Supplies
Imagerunner 5000 error code e000202 , what mean ? thank
This error code is referencing your scanning lamp just beneath the document feeder. Specifically, it is stating that the home position sensor that detects when the scanner assembly is to the further most left side is malfunctioning. However, as a copier technician, I would advise against pursuing any sort of remedy yourself, as there are numerous high voltage components on the scanner assembly that present a possible danger. Not to mention replacement parts are extremely expensive if you accidentally blow anything out.
My advise, contact someone who is trained in servicing these machines.
Oct 30, 2010 | Canon imageRUNNER 5000 Copier
Error 301
that code is related to the scanning lamp
Mar 22, 2010 | Canon imageRUNNER 400S Copier
How can i remove a E005 on a have a canon np6330.they is no aditional function key.if posible pliz give me the key code to reset the machine
E005 code means that the Fixing web needs to be replaced. Even if you were able to reset the code, the machine will start jamming with extreme frequency and deteriorate (damage) the Fixing rollers. I recomend having a qualified service tech remedy this error.
Jun 11, 2009 | Canon imageRUNNER C3200 Copier
Canon Irc2105 Colore Copyer Machin
E215 -The thermistor of the scanning lamp (fluorescent lamp) exceeds
a specific temperature, check your scan lamp
Apr 05, 2009 | Canon imageRUNNER C3200 Color Printer
I have a Canon Imagerunner 7095 copier and keep getting the same error code when I attempt to start the copier: Error Code E000532-8001. Any suggetsions
There is something wrong with the finnisher,check if the stapler unit is not stucked and in the home possition.Check if the finnisher trays is not stucked.
If it is an external finnisher you can unplug it and move it away from the machine.and you will be able to carry on copping wile wating for tech support.
Dec 19, 2008 | Office Equipment & Supplies
Mar 13, 2008 | Canon imageRUNNER 2200
11,366 people viewed this question
Ekse
Marvin
Marvin
