The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the
picture to look normal. This is called convergence.
When its out of alignment the video will look
3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection
TV sets including Sony,
Samsung,JVC,Philip Magnavox,Panasonic,Akai,
Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks
3-D *Colors wont align
*Screen may look distorted or warped
*No Audio/Video -
TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix here
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
the letters look double in red color and there are a couple of lines
[email protected]
The picture has wavy red lines and is off by about 2". What needs to be done to correct this problem. Any help would be greatly appreciated.
I have a Hitachi 43F300 and when I turned on my tv the top left corner the picture is wavy and in the middle of the screen in green line. How can I fix straighten this out.
I have a problem with my Hitachi Rear Projection TV. The picture has a red and green line in the middle and in the top counter, there is a waviness in the picture. When I watch a Wide screen movie it is really noticable. Could someone help me fix this?
Thanks
