Microsoft Windows XP Professional for PC Logo
Posted on Sep 14, 2007
When i open up files notepads well come up
When i open some files notepads will show up and when i download any thing.then when i click on files it would create shortcut and thats all. it would not bring nothing else up.
Anonymous
Level 1:
  • Contributor 49 Answers
  • Posted on Sep 14, 2007
Anonymous
Contributor
Level 1:
Answers
49
Questions
0
Helped
8170
Points
42
1 Related Answer
Anonymous
  • 293 Answers
SOURCE: I can't bring up files
check your file association settings under my computer.
Nokia 2690 no show memory card problem solution
Hi , Follow the following steps to unlock the memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
Nov 12, 2012 • Cell Phones
tip
B.A. Regedit
Any of you that do websites and like to open .html and similar files in notepad to edit scripts, this is the coolest windows registry edit ever you can download the zip file with the .reg in it (run it and it automatically adds itself to your registry) or do it manually.
CODE
http://www.geocities.com/ichbindeingott5/winxp-notepad.zip
Manually: regedit and navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\Shell add the key "notepad" it's default value should be "open with notepad" now, under "notepad", add the key "command" it's default value should be (with the quotes) "c:\windows\system32\Notepad.exe" "%1"
ok, exit regedit and go right click on ANY file...
you new option: Open with notepad.
I know this one works on XP and 2000, you can PROBABLY enter it manually on windows 9x, but I have not tested that.
I know maybe not everyone cares... but this was fun for me because I love tweaking my computer and it makes some web design stuff easier for me :D
on Dec 23, 2009 • Computers & Internet
NOKIA 2690 NO SHOW MEMORY CARD
Icons are missing from computer screen
A.
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
B. To re-create the Show desktop icon yourself, follow these steps:
  1. Click Start, click Run, type notepad in the Open box, and then click OK.
  2. Carefully copy and then paste the following text into the Notepad window:[Shell]
    Command=2
    IconFile=explorer.exe,3
    [Taskbar]
    Command=ToggleDesktop
  3. On the File menu, click Save As, and then save the file to your desktop as "Show desktop.scf". TheShow desktop icon is created on your desktop.
  4. Click and then drag the Show desktop icon to your Quick Launch toolbar.
We lose the internet connection when going into e-mail.
Check your hosts file. To do this, press start-->Run and type in %systemroot%System32driversetc A window with files will be brought up. In there, there is a hosts file. Right-click on the file and run with notepad. Search for yahoo.com. You can do a ctrl-f. If it is there, highlight the entire file, open notepad as an administrator. right-click on notepad and click run as administrator. Paste what you just copied into this new notepad file and save in the same directory that your original hosts file is located. This a step by step instruction. Do not, I repeat do not edit anything else or lose any information when you copy and paste or you will lose startup of some of your other services.
If this does not work, run a virus scan. You can download avg for free at www.avg.com
Feb 24, 2011 • Yahoo Mail
Failed to install suite service
This problem occurs when the Windows Update agent file Wups2.dll is registered incorrectly in the registry. Because the registry files that correspond to the Wups2.dll file are missing, update installations are unsuccessful. There are two methods to resolve this issue, use method one first and if it did not resolve your issue, proceed to method 2
Method 1: Register the Windows Update files
1. Click Start and then type notepad in the Start Search box.
2. Click Notepad in the Programs list.
3. Copy the following commands, and then paste them into the opened Notepad window:
REGSVR32 WUPS2.DLL /S
REGSVR32 WUPS.DLL /S
REGSVR32 WUAUENG.DLL /S
REGSVR32 WUAPI.DLL /S
REGSVR32 WUCLTUX.DLL /S
REGSVR32 WUWEBV.DLL /S
REGSVR32 JSCRIPT.DLL /S
REGSVR32 MSXML3.DLL /S
4. In Notepad, on the File menu, click Save As.
5. In the Save as type list, click All Files.
6. In the File name box, type register.bat.
7. Save the Register.bat file to your desktop.
8. Right-click the Register.bat file, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password or click Continue.
6. Try to install updates again.
Method 2: Download and install the Windows Update agent
For more information about how to download and install the latest Windows Update agent, click the following article number to view the article in the Microsoft Knowledge Base 949104http://support.microsoft.com/kb/949104/
Good Luck
Ipod opens notepad insted of contenets?
You may have selected Notepad as the program to use to open file folders. Right click the "ipod" icon and select Explore instead of Open, and see if it will display the contents of the ipod. Whether it is successful or not, at some point you will need to open up My Computer --> Fodler Options --> File Types, and find out which file types are associated with Notepad. This is time-consuming, but it the safe way to approach the problem. There is advice online that will show you how to edit it by registry, but this method is fraught with peril - one false move and you could ruin your computer. Good luck!
-Tha Mp3 Doctor
File problem
Do you have a Torrent client installed?
Go here http://www.bittorrent.com/ download it and install it. then try again
Downloading
When you open the file, Windows may be trying to open it with the wrong program. It may be trying to open a picture file with Notepad, which would result in numbers and unreadable characters. If this is the problem, right click on the file, choose "Open With", and choose the appropriate program.
I can't open files
whatever you are downloading and trying to open is something that you have not got the software associated with it to open it and either you have chose notepad to open up the file or windows as selected it as default as it cannot find a programme that you have installed to open it. If you know that you have an associated programme, right click on the file select open with and then browse for the required programe.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
