SOURCE: How to change Ink in the Canon Mp490 Printer?
Hello
You can get help from this video
Hope this helps, if so do rate the solution
SOURCE: Canon MP490 printer error code 5011
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints. that should solve it!!
SOURCE: How do I locate the serial number on a Canon PIXMA
Generally the serial number is on the back or the bottom of most electronic items
SOURCE: How do I change the
its on the menu-device setting-language
or you cant understand the language just follow this steps
1. first click MENU its on the upper right side icon.
2. press the arrow up once then press ok.
3. press down 8 times.
4. then you can see the language menu, select what language you want.
SOURCE: free download canon pixma mp490 printer driver
Check out this link @ Cannon Support USA
Select your OS to download your required Drivers & Software.
Hope it helps.
