from what little ive found its been said this could be a firmware issue that toshiba can send a usb card to fix. the green light is on the power side and flashes three times then repeats. according to the service manual this is a step to allow the television to warm up before the screen fires. tv worked perfect for over three years then this came outta no where! PLEASE HELP!!from what little ive found its been said this could be a firmware issue that toshiba can send a usb card to fix. the green light is on the power side and flashes three times then repeats. according to the service manual this is a step to allow the television to warm up before the screen fires. tv worked perfect for over three years then this came outta no where! PLEASE HELP!!
You can't post conmments that contain an email address.
that didnt help. the screen wont fire. you here it click when you hit the power buttton but the screen wont even attempt to turn on after the click as it normally has. the green light just continues to blink in sets of 3 then repeat.that didnt help. the screen wont fire. you here it click when you hit the power buttton but the screen wont even attempt to turn on after the click as it normally has. the green light just continues to blink in sets of 3 then repeat.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
Model number given indicates it should be a 2000 year model.
If so, it should have the self check feature; try to turn the set on and when the green light goes off: On the front of the set press and hold both the menu and input buttons for at least five seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks,pause and 2 blinks (2,2 error code is most common one). It will repeat the error code several times.
Let me know what error code you find and I will tell you what it may mean.
if this told you something you did not know rate this solution as "very helpful" as I do this here for free.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
