When I attempt to set microphone level I get an error message that says PowerPoint is not picking up sound from the microphone. I cannot continue past that to record narration. I know that the microphone is working as it is recognized/tested outside of PowerPoint. How do I correct? I am stuck.
?Earning money online is very easy nowadays. Earns every month online more than $17k by doing a very easy home based job in part time. Last month I made $19754 from this job just in my spare time, which is only 2 hrs a day. Very easy work to do and earning from this is awesome. Everybody can get this right now and start earning cash online by following instructions on this webpage............. GOOD LUCK???www.now37.com
1. Check the privacy settings. Microsoft has taken privacy very seriously in Windows 10. Users need to specifically confirm what apps can access their camera or microphone. Otherwise, apps won't be able to record audio or video input.
2. Run the audio troubleshooter. Windows 10 has a dedicated troubleshooter that detects and repairs problems with recording audio.
3. Update your sound drivers. Outdated or corrupted audio drivers might also prevent PowerPoint from recording audio on the presentation slides.
4. If you can't fix PowerPoint recording without sound by following the steps above, you can try other methods to record PowerPoint with audio in this tutorial: How to Record PowerPoint Presentation?
Install, the driver for the microphone
SOURCE: linking sound wave files to PowerPoint
Hi Rose,
Instead of copying presentation directly to CD, simply do Package on CD (File menu --> Package in CD, then copy to a folder or directly burn to CD
it will contain everything required to run presentation your PPT file, Powerpoint Viewer and all supporting files.
any ways having problems pl contact me
Zulfikar Ali
[email protected]
9899780221
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices
Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure
that there is not a check-mark in the MUTE box against microphone in the list
of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't
checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here SELECT microphone as an input source for recording
(as opposed to un-checking mute in the playback controls).
NOTE if your microphone
is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES
on the tool-bar and place a check against microphone in the list
entitled 'show the following volume controls' and then click OK. Same
applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume
as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust
slider to suit.
You might put a check mark in the box
to show the volume control on the Task Bar so you can go straight to it to make
adjustments in the future.
