My whirlpool refrigirator model # ed25texhwoo does not get cold nor does the freezer work. I havent connected the water line yet. Could that be my problem?
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge? When have you last changed the water filter. Should be down below at the front grille! Try these tasks!
If the ice maker is not producing ice or not enough ice Refrigerator connected to a water supply and the supply shutoff valve turned on? Connect refrigerator to water supply and turn water shutoff valve fully open. • Kink in the water source line? A kink in the line can reduce water flow. Straighten the water source line. • Ice maker turned on? Make sure wire shutoff arm or switch (depending on model) is in the ON position. • New installation? Wait 24 hours after ice maker installation for ice production to begin. Wait 72 hours for full ice production. • Freezer door closed completely? Firmly close the freezer compartment door. If the freezer compartment door will not close all the way, see "The doors will not close completely." • Large amount of ice recently removed? Allow 24 hours for ice maker to produce more ice. • Ice cube jammed in the ice maker ejector arm? Remove ice from the ejector arm with a plastic utensil. • Water filter installed on the refrigerator? Remove filter and operate ice maker. If ice volume improves, then the filter may be clogged or incorrectly installed. Replace filter or reinstall it correctly. • Reverse osmosis water filtration system connected to your cold water supply? This can decrease water pressure.
Let me know how it goes! Huuum Please remember to leave a rating!
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
