I had a paper jam in the printer. I removed the paper and I still receive the error message. How do I fix this?
Hi, 2 things to check. First when you lift and close the toner door, do the exit rollers on top of the printer turn for a couple of seconds. You just put your fingers where the paper comes out and see if they turn. If they do not then you may have a fuser or coupling gear isse. The other thing is to try and feed the paper from the manual feeder and see if it goes thur. If it does you have a sensor issue on the paper input unit and a sensor board will have to be replaced. If the exit rollers are not turning and the paper does not make it into the fuser, I would suspect one of the gears on the fuser has failed. Remove the fuser and inspect the gears and I am sure you will find the problem. Good Luck
Everything seems to be rolling correctly but the paper jams every time I try to print
We get a paper jam error the first time we try to print even though the paper just passes through. We retry and the second time through it normally prints but overall I have not been impressed with the HP6110.
Paper Jam and paper is stuck inside machine - how do I open it up to get the paper out.
The first 4 or 5 months the printer worked flawlessly. We aren't heavy printers, however, the kids use it alot for homework and that is the reason we purchased this printer. For no apparent reason now everytime we try to print we get a paper jam. Sometimes the paper passes through, but mostly it just goes in partway and stops. I pull the paper out, open and close the front cover, and reinsert the paper and this usually fixes the error. Any solutions would be helpful.
When I try to print something .
I get an errror message paper jam
joe bentley
The error message will not go away even though there is no jammed paper so the printer has been rendered useless
paper jammed error message will not go away and printer is useless
I can not print. The paper is not pass. I only see " paper jammed". I hear loud grinding sound.I do not know what I can do.
Having the same problem that everyone else is describing. We do not use the printer that frequently and today we had a paper jam. Removed the paper from the back as the manual prescribed, but can't use the printer now. The printer grinds and then says paper jam again. I can't find anything to be removed.
Regularly get a paper jam when I have not used the printer for a few days. This has happened since I first bought the printer 18 months ago
PRINTER ERROR 024-910 BUT THRE IS PAPER STILL WONT WORK
