My printer is not printing in blue. Colour cartridge is present but it is only printing black, pink and yellow during test after installation
SOURCE: Lexmark 3200 colour printer
Dear friend There may be serious problem in the printers mother board which is not sending any signals for the bklack cartridge and should be diagnosed. Pran
SOURCE: cannot obtain yellow colour.
Clean the Nozzles of the printer, you can do this by the printer driver.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: My Lexmark Z600 has stopped using the colour 27
apparently the default printing color has been changed, you have to change it back either from "control panel/ printers /right click on your printer and click properties, and choose color for printing." or you can do it per printing job, when it shows u the printing options, (like number of copies and other (basically same window from the control panel). if you do it from the control panel whatever you choose, that would be the default, otherwise it is per job change and is not permanent.
SOURCE: Lexmark Z615 inkjet printer - whetther I print in
The problem with your printer is the print head. Usually you have to run the clean nozzle thing 5 or 6 times to clean the print head nozzles and if there's still no improvement after that then print head needs to be changed for the printer to work properly. The bad news is that a print head costs almost as much as a new printer.
SOURCE: printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
