Hello Derek, thank you for your inquiry! Generally speaking, E90 commonly indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about 30 seconds. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs. I hope this information helps to some degree.
get series MP258 printer. According to my experience of Error P10 can be solved by replacing one or more of the following ...
are you saying unplug it ??
I had the same error, I replace the control Board- part # 137007010 , $ 145.24 with free shipping for searspartsdirect.com. Easy repair, 2 screws to take the top, 4 screws to take the top panel and 6 screws holding the control board. When I saw the heat applied to the board, it is an indication of cold solder or broken SMD ( surface mount components) , it could it been a resistor or Capacitor. Thanks for tip. Regards, Fady.
