20 Most Recent Metz Mecablitz 60CT4 TTL Flash Questions & Answers
You should be able to source on from Ebay, although due to the age of the flash it might not be easy. A word of warning - if you intend to use this flash with a modern DSLR, be aware that the trigger voltage on older flash units is far higher than that with which DSLRs can cope, and can result in permanent damage to your camera.
Metz Mecablitz... | Answered on Mar 29, 2017
Older unit. This may be helpful.
http://www.bhphotovideo.com/FrameWork/charts/comp_metzflash_leica.html
Metz Mecablitz... | Answered on Feb 20, 2015
The couple of dryfit batteries I've looked at have been shot. I don't know how old they were. Take a decent modern battery charger (the ones at WallMart are good enough) that will handle 6 volt and AGM batteries. Clean the contacts and jury rig a way to connect the charger to the battery terminals. If the charger doesn't register anything, it's likely the batteries have died. They will actually completely dry out inside, becoming inert. I've used $20 AGM batteries from Batteries Plus and they seem to work fine (though you either need to make a battery adaptor, or cut out the side of the battery pack to get them to fit.
Metz Mecablitz... | Answered on Feb 06, 2015
Although you can still get lead acid batteries from Sonnenschein (the original oem manufacturer) for the Metz CT60 units, a better choice are the Lithium ferrite phosphate or Lithium ion batteries, now available on ebay. For example sales8phd on ebay sells a drop in replacement 6 or 7Ah battery with a charger for ~$75. In general these batteries produce more flashes per charge than the lead acid oem batteries,particularly when shooting a lot of flashes in rapid sucession.
EBay, if that's what you want. The metz "chargers" are just 7 volt ac transformers - they supply 7 volts to the battery pack which has the actual charging circuit in it. I haven't pulled one apart yet, but I'm guessing they're very rudimentary chargers. Depending on what you're using for a battery you might want to use a modern external smart charger. I use $20 AGM batteries from batteries plus (instead of the $80 metz batteries) and use an external charger from WallMart on them. It's quick, lets me see the current charge state, won't overcharge the battery, and works on my car and boat batteries too.
The Orange Light will light up on the flash.
You are going to need a new battery if it's older than 6 years old.
atdlee@netzero.com
Metz Mecablitz... | Answered on Jan 18, 2015
You have to use a special cable adapter for each type of camera.
These old flash units do not have adapters for current digital cameras. For old cameras the only place to get the adapters, is on ebay or from KEH.
Metz Mecablitz... | Answered on Jan 08, 2015
Center of PC Sync Plug is Positive.
Outside is ground,
atdlee@netzero.com
Metz Mecablitz... | Answered on Nov 27, 2014
You have two.
atdlee@netzero.com
Metz Mecablitz... | Answered on Nov 19, 2014
Four Screw on the bottom of Head.
Be very careful, its 330V waiting to kick you.
atdlee@netzero.com
A new dryfit battery is delivered fully loaded. So you will not have to charge it the first time. My 5 year old dryfit battery still is holding enough energy to help me through the darker moments. I have it charged now once after an average of 400/500 flash pictures (when do you need full power with this flash?), which is every two to three weeks (normal hobby use).
Metz Mecablitz... | Answered on Oct 18, 2014
Send the flash to the manufacture or their authorized service rep for proper service. These capacitors are charged to high voltage and are discharged with very high current.
There are serious safety issues with these capacitors. The flash manufactures normaly will not give out service information or supply support for self service. There are serious liability and safety issues involved.
For personal interest, below is a very good article on basic capcitor theory and history. If you have a background in physics and math, this article can be well appreciated.
http://en.wikipedia.org/wiki/Capacitor
Jerry G.
Just the PC Sync Cable that came with the flash.
Open the left side (rubber flap) of the camera, insert the the cable into the silver round circle with a center dot (camera's PC Sync Socket.
Set camera to "M", ASA/ISO to 400 on both, set 125 on camera, set camera/flash to F5.6.
atdleeatnetzerodotcom for more help.
Metz Mecablitz... | Answered on Jan 07, 2014
Contact me.
I am in USA.
Do you have friends in USA?
Shipment to India can be costly.
atdlee@netzero.com
Metz Mecablitz... | Answered on Oct 15, 2012
About 8 seconds is normal. Metz actually instruct owners to discharge the flash at full power every month to preserve the capacitor, which you haven't done. I confess I don't always do that either. But just fire it off till the battery goes flat, and then recharge and try again. This has always improved the performance when I have done it. Basically, they like to do heavy work, and like muscles, get better for it. That sounds silly, but it is true. There is an electrochemical explanation. As you are not sure what capacitor to use, I would recommend taking the unit to Foto Reisel in Sydney if it is near you. They can get the unit serviced for you. You can also send an email to Metz. They understand English, and if servicing the unit is difficult in your location, and you sound capable of fixing it yourself, they may sell you or tell you an equivalent part. BE CAREFUL THOUGH. THAT THING CAN EASILY STOP YOUR HEART!
Metz Mecablitz... | Answered on Oct 08, 2012
Metz Mecablitz 60CT4 TTL Flash Logo
Popular Tags
59 questions posted
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
View Most Popular
Metz Cameras
  • Metz Cameras
Most Popular Question
metz 60 ct 4 batteries capacitors
  • Cameras
