Televison & Video Logo
John D Posted on Jul 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a 52" Polaroid for like 50$ and the
I bought a 52" Polaroid for like 50$ and the screen itself.is okay. Buy there's these to big white circles.the size of baseballs. No pixels. Im wonder what is wrong. How much will it cost.to fix. And can I do it myself?
bobby caesar
Level 2:
Champion:
  • Expert 247 Answers
  • Posted on Jul 19, 2013
bobby caesar
Expert
Level 2:
Champion:
Answers
247
Questions
Helped
28538
Points
498
The white circles are called halos caused by technically a burn-in u either ignore or change the screens particularly the one on the inside for a new one......the halos have made a burn-in on the screen its like taking a spot light and pointing it to a surface for long the light will eventually image its circular image on the surface like a discolouration hence the snow like white balls as u call them....another suspect the optical dome glass maybe dirty u got to open the box screen chamber and use a soft cloth to clean it
5 Related Answers
Anonymous
  • 14553 Answers
  • Posted on Jan 30, 2010
SOURCE: I have a double screen , bended on the sides what
You can fix it yourself but it involves two things--being able to get at the convergence chips and being able to solder etc....
Not a difficult repair and total parts cost should be under 30 dollars.
Let me know if you need help as I am here to help.
I will give help and options if you ask.
IF THIS HELPED YOU rate this solution as I do this here for free.
SD TECH
Testimonial: "pointed me in the right direction thanks"
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Aug 02, 2008
SOURCE: I bought a used 52''
The opto couplers are usually what cause that problem in the phillips models.
Anonymous
  • 319 Answers
  • Posted on Aug 04, 2008
SOURCE: PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Anonymous
  • 2920 Answers
  • Posted on Feb 04, 2009
SOURCE: Sony 52 inch projection Screen keeps shutting off.
not if it keeps repeating the same cycle over and over..it cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Anonymous
  • Posted on Oct 08, 2009
SOURCE: old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
2helpful
2answers
Polaroid TV 50". I have a fault across bottom of screen, a transparent band about 2 inches high. Can it be fixed and is it worth it?
No Model number, '50 inch' is just a size.
Can it be fixed? Yes, they can all be fixed.
Is it worth it? Unlikely. Polaroid are a camera maker and don't have a good name in televisions.
Hopefully our television @Larry will be along to confirm.
https://www.google.com/search?q=Polaroid+TV+50%22+fault+across+bottom+of+screen%2C+transparent+band+about+2+inches+high
Polaroid 32
Polaroid is the other non-brand name products, made in a limited quantities and used well known logos as a bait for consumers. Those are: "element", "mag', "magnavox", and polaroid itself. the only one advantage of early "polaroid" is: display panel has been made by real Polaroid, then. what made the picture quality outstanding, compare to other "bunch". even though they use similar hardware and design. Many real Polaroids were junked few years ago, due to inability to get any product support: i.e. hardware for a reasonable price. that's why you have got into the problem: there is NO support for the product, not even "factory exchange only"! That's what we, the Repair Men, find at the 'parts distributors". Those must be sitting on direct payroll from People's Republic. They trying to price replacement parts well above the cost of new unit. Example: 52" Sharp LCD panel cost: $2,695.00 plus s&h! and that's for 5 years+ set! Make up your mind about 'support" and start to repair your set. In most cases it will be very reasonable, especially if your set was your 'baby". don't try to replace it now: closer to the date, TVs are becoming more and more "toys"! Built to break! how would you support growing economy and wealth of those "people's republics'? By robbing yourself of the daily pleasures!
good luck in your discovery,
thanks,
Alex.
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
1helpful
Blue line down right side
The blue line came on to the tv LCD screen panel by itself,not caues by u or an object by hitting the tv LCD screen panel itself wright,if yes this problems can't be repair because the LCD screen panel itself dead.Blue line happen by itself,the tv board that call the T-CON board it is dying and the causes.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacemrnt.
HDRCA 52" model R52WH77, the pic looks like a big U in the middle of the screen and it turns its self on after turning it off. Sound is fine.
A capacitor is building up power and then when there is too much power it discharges turning the tv back on without you hitting the power button. The tv will need to be repaired by a service tech however get a quote and then decide whether it is better to just buy a new tv. LCD's have dropped in price greatly.
1helpful
2answers
I have a 52' big screen and the picture is shoing
Ur convergence is dead,go to ebay.com buy the convergence repair kit.Find out ur make and models,and manufactures of ur TV buy it.
All big projection DLP have this prob. one time or other every manufactures,Sony,Samsung,RCA,many others.
5helpful
2answers
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Can i fix it
Polaroid screens are generally expensive. It would probably be cheaper to buy a new camera altogether.
However, having said that, please check around the repair shops for a quote first, before you decide to buy a new one..
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
